Last updated by Andrey 1 year, 9 months ago.
Assisted by: Andrey.
August 30, 2023 at 7:45 pm #14315943 | |
rigdenA |
I have custom script added to woocommerce product pages for rental period. That calculates price for customer. Unfortunately It doesn't show up on translated version. For example: Original language: Translated language: |
August 31, 2023 at 9:25 am #14318675 | |
Dražen Supporter
Languages: English (English ) Timezone: Europe/Zagreb (GMT+02:00) |
Hello, 1) In order to expedite handling your support requests, can you please share WPML support debug information from your site. - To give debug information, login to your site and go to WPML → Support. From there click on the “debug information” link at the bottom of the page. More information on the link: https://wpml.org/faq/provide-debug-information-faster-support/ 2) Can you please explain how are you adding his script to your default language page? 3) Please explain how it is missing, it is just not working on your 2nd language page or? Thanks, |
August 31, 2023 at 7:53 pm #14323449 | |
rigdenA |
Hi Thanks for reply 1) I did not find any box or place where to add debug information. Im pretty sure I added it when I opened this ticket. Check again please.. 2) This script is added to functions.php // Add a custom field before single add to cart add_action('woocommerce_before_add_to_cart_button', 'display_single_product_custom_fields', 5); function display_single_product_custom_fields() { if(!enable_rent_to_cat()) return; // Get the rental days data options $options = array('' => __("Valitud periood", "woocommerce")) + get_rental_days_options(); echo '<div class="custom-text text"> <h5>'.__("Vali rendiperiood ja kuupäev", "woocommerce").'</h5> <label>'.__("Algus", "woocommerce").': </label> <input type="date" name="rental_date" value="" class="rental_date" required title="Vali rendi algus kuupäev" required /> <label>Periood:</label> <select class="rental-days" id="rental-days" name="rental_days" required title="Vali rendiperiood" required>'; foreach( $options as $key => $option ){ echo '<option value="'.$key.'">'.$option.'</option>'; } echo '</select> </div>'; } // Get custom field value, calculate new item price, save it as custom cart item data add_filter('woocommerce_add_cart_item_data', 'add_custom_field_data', 20, 3); function add_custom_field_data($cart_item_data, $product_id, $variation_id) { // HERE set the percentage rate to be applied to get the new price $percentage = 100; if (isset($_POST['rental_date']) && !empty($_POST['rental_date'])) { $cart_item_data['custom_data']['start_date'] = $_POST['rental_date']; } if (isset($_POST['rental_days']) && !empty($_POST['rental_days'])) { $cart_item_data['custom_data']['rental_days'] = esc_attr($_POST['rental_days']); $_product_id = $variation_id > 0 ? $variation_id : $product_id; $product = wc_get_product($_product_id); // The WC_Product Object $base_price = (float) $product->get_regular_price(); // Get the product regular price //$price_rate = $cart_item_data['custom_data']['rental_days'] * $percentage / 100; $price_rate = get_rental_rates($cart_item_data['custom_data']['rental_days']); $cart_item_data['custom_data']['base_price'] = $base_price; $cart_item_data['custom_data']['new_price'] = $base_price * $price_rate; } // Make each cart item unique if (isset($cart_item_data['custom_data']['rental_days']) || isset($cart_item_data['custom_data']['start_date'])) { $cart_item_data['custom_data']['unique_key'] = md5(microtime().rand()); } return $cart_item_data; } // Set the new calculated cart item price add_action('woocommerce_before_calculate_totals', 'extra_price_add_custom_price', 20, 1); function extra_price_add_custom_price($cart) { if ( is_admin() && ! defined( 'DOING_AJAX' ) ) return; if ( did_action( 'woocommerce_before_calculate_totals' ) >= 2 ) return; foreach($cart->get_cart() as $cart_item) { if (isset($cart_item['custom_data']['new_price'])) $cart_item['data']->set_price((float) $cart_item['custom_data']['new_price']); } } // Display cart item custom price details add_filter('woocommerce_cart_item_price', 'display_cart_items_custom_price_details', 20, 3); function display_cart_items_custom_price_details($product_price, $cart_item, $cart_item_key) { if (isset($cart_item['custom_data']['base_price'])) { $product = $cart_item['data']; /* echo "<pre>"; print_r($cart_item); echo "</pre>";*/ $base_price = $cart_item['custom_data']['base_price']; $price_rate = get_rental_rates($cart_item['custom_data']['rental_days']); $product_price = wc_price(wc_get_price_to_display($product, array('price' => $base_price * $price_rate ))). '<br>'; if (isset($cart_item['custom_data']['rental_days'])) { $rental_days = get_rental_days_options(); $product_price .= $rental_days[$cart_item['custom_data']['rental_days']]; } } return $product_price; } // Display in cart item the selected date add_filter('woocommerce_get_item_data', 'display_custom_item_data', 10, 2); function display_custom_item_data($cart_item_data, $cart_item) { if (isset($cart_item['custom_data']['start_date'])) { $cart_item_data[] = array( 'name' => __("Rendi algus", "woocommerce"), 'value' => date('d.m.Y', strtotime($cart_item['custom_data']['start_date'])), ); } if (isset($cart_item['custom_data']['rental_days'])) { $rental_days = get_rental_days_options(); $cart_item_data[] = array( 'name' => __("Rendiperiood", "woocommerce"), 'value' => $rental_days[$cart_item['custom_data']['rental_days']], ); } return $cart_item_data; } // Save and display custom field in orders and email notifications (everywhere) add_action( 'woocommerce_checkout_create_order_line_item', 'custom_fields_update_order_item_meta', 20, 4 ); function custom_fields_update_order_item_meta( $item, $cart_item_key, $values, $order ) { if ( isset( $values['custom_data']['start_date'] ) ){ $date = date( 'd.m.Y', strtotime( $values['custom_data']['start_date'] ) ); $item->update_meta_data( __( 'Rendi algus', 'woocommerce' ), $date ); } if ( isset( $values['custom_data']['rental_days'] ) ){ $rental_days = get_rental_days_options(); $item->update_meta_data( __( 'Rendiperiood', 'woocommerce' ), $rental_days[$values['custom_data']['rental_days']] ); } } 3) It is not showing up on 2nd language. |
September 1, 2023 at 8:06 am #14324961 | |
Andrey WPML Supporter since 06/2013 Languages: English (English ) Russian (Русский ) Timezone: Europe/Kyiv (GMT+03:00) |
Thank you for sharing the information. Your script needs to be debugged to say what is wrong. But we cannot debug it as this is out of the scope of our support. I suspect, at some point, your script fails in secondary languages. That could explain why it doesn't show. You are getting product ID in your script, which could be different in secondary languages. I suggest adjusting this by using the 'wpml_object_id' filter. Here's more information: Please also refer to the WCML Hooks Reference page: I hope this helps. |
September 1, 2023 at 9:45 am #14325689 | |
rigdenA |
Hi, Thanks, got it fixed. Seemed it messed up categories hierarchy, which caused script not to work. I synced categories again and now it is working. |
