The client was experiencing issues with duplicate translation fields in the WPML translation backend when translating a page from German to English. Additionally, there was a problem with the Complianz Plugin where the text of the cookie consent banner was not updating in WPML.
For the issue with duplicate translation fields:
1. Navigate to WPML -> Settings -> Custom Fields Translation.
2. Search for
mfn-page-items-seo
and set it to "Don't translate".
3. Edit one of the pages where the issue occurs, make a minor modification in the original page, such as adding an extra space.
4. Update the translation.
For the issue with the Complianz Plugin's consent banner text not updating:
1. Go to Complianz and switch to English in the admin top bar.
2. Navigate to Consent Banner > Text > Cookie Message.
3. Save the German text in a notepad, edit the text in there, and save it as an English text.
4. Go to WPML -> String Translation and search for part of the banner, e.g., 'To provide you with an optimal', and mark the option 'Include Translation'.
5. If the string is in another language, select it and change it to English/en.
6. Add the German text that you saved before as a translation.
If these solutions do not resolve your issues or if they seem irrelevant due to being outdated or not applicable to your case, we recommend opening a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please contact us in the WPML support forum at https://wpml.org/forums/forum/english-support/.
Last updated by Mateus Getulio 1 year, 3 months ago.
Assisted by: Mateus Getulio.
April 2, 2024 at 9:37 am #15471762
danielK-19
Hi There,
Translating this page from German to English it shows all the translation fields double in the WPML translation backend. For now this is OK, as only the developers are working on the site. But end of the week we will be transfering the site to the company – by then we would like it to show properly – the translation only once.
We are using WPML and the BeTheme and before being able to start translation, I had to take these steps to make the translastion fields visible at all: hidden link
Could you please help me – if you tell me how, I will be happy to give you access, as the pages are now still in draft modus.
Many thanks and best regards,
Daniel
April 2, 2024 at 7:30 pm #15474922
Mateus Getulio
Hello Daniel,
Our Debugging Procedures
Privacy and Security Policy
**IMPORTANT**
Please, let me know if you need any additional details. Have a nice day.
April 3, 2024 at 11:15 am #15477679
Mateus Getulio
Hello there,
I checked it and the double fields in ATE were coming from this custom field: mfn-page-items-seo. Since this field isn't needed for translating the page, I fixed this issue by following the steps:
- Go to WPML -> Settings -> Custom Fields Translation
- Search for mfn-page-items-seo and set it to the default "Don't translate"
- Edit one of the pages where the issue happens, make a minor modification in the original page, like adding an extra space
- Update the translation
After doing it, I was no longer able to replicate the issue with the duplicated fields.
Please give it a try and let us know the results.
Mateus
April 3, 2024 at 2:38 pm #15479024
danielK-19
Hi Mateus,
Thank you so much for your quick help – that worked.
Now I only have one more little problem – in the Complianz Plugin I´ve changed the text of the coockie consent banner (see Complianz-Screenshot) – but it doesn´t transport to WPML where it is shown with the old text (see WPML-Screenshot).
Could you please help me here too?
I´ve already tried everything, clearing all caches and includings this tipp https://wpml.org/forums/topic/can-i-change-the-text-of-the-original-english-string/ but nothing seems to work.
Thank you very much
and best regards,
Daniel
April 3, 2024 at 8:39 pm #15480460
Mateus Getulio
Hello there,
I was able to translate the Consent Banner by following these steps:
- Go to Complianz and switch to English in the admin top bar
- Go to Consent Banner > Text > Cookie Message
- Save the German text in a notepad for you to use it later, edit the text in there and save it as an English text
- Go to WPML -> String Translation and search for part of the banner eg.:'To provide you with an optimal', mark the option 'Include Translation'
- If the string is in another language, select it and change it to English/en
- Add the German text that you saved before as a translation
Now when I check the front end I can see both consent banners for each respective language.
Can you please check it and tell us if it's working as expected now?
Thank you, please let us know.
Mateus
April 4, 2024 at 8:07 am #15481381
danielK-19
Hi Mateus,
Thanks for your promt help – and the explanation of the steps, how you got there. That for sure will be a great help for the future.
As for me – mission accomplished!
Daniel
