You are experiencing issues with product translations being automatically duplicated and published when you duplicate the original product using the WooCommerce duplication option.
We recommend using a different plugin that handles the duplication process without affecting other languages. Specifically, you can try using the Duplicate Page or Duplicate Post plugins. These plugins provide more control over the duplication process and should prevent automatic duplication across different languages.
If this solution does not resolve your issue or seems outdated, please check the related known issues and confirm that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket for further assistance.
This topic contains 7 replies, has 1 voice.
Last updated by ziga pipan 1 year, 1 month ago.
March 10, 2025 at 10:46 am #16795734
ziga pipan
I have webstore in SI (original) HR and ES language. I have a lot of specifications and ACf's for a product, so when adding a new one it's easier for me to duplicate a product instead of creating a new one, then translate it. So what I do is dupolicate for exapmle "product01" in SI language. I rename it to "product30" and save it as draft so I have days to get everything ok. Problem is, product gets duplicated in HR and ES languages as well, and published with name "product01 (copy)". So when I do that for multiuple products I get this published in HR and ES versions:
product01 (copy)
product01 (copy)(copy)
product01 (copy)(copy)(copy)
product01 (copy)(copy)(copy)(copy)
how can I avoid this?
up above
How can I avoid products being automatically duplicated and published in HR and ES languages when I duplicate them in SI language?
March 10, 2025 at 12:15 pm #16796343
Dražen
Thanks for contacting us.
How are you duplicating the product? If you are doing so with the WPML duplicate option from the language box, it will duplicate only in that language:
- https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
I assume you are using built-in duplicate option or from some duplicate plugins, that one will then duplicate to all languages.
Let us know if this helps.
Drazen
March 10, 2025 at 1:22 pm #16796678
ziga pipan
Yeah, but first I gotta duplicate a product in original language, so I'm using this Duplicate option
March 11, 2025 at 12:10 pm #16801499
Each plugin to duplicate pages or posts handles the translation differently, but it is not something that is controlled by WPML.
In your case, you seem to use the WooCommerce Duplication Option, which is something that is controlled by WooCommerce.
For example, if you use "Yoast Duplicate" the translation will be duplicated.
You could give it a try with an alternative plugin, like "Duplicate Page" or "Duplicate Post".
March 11, 2025 at 1:15 pm #16801828
ziga pipan
So what are you saying is I'm not supposed to be duplicating products in original language, but creating a new one each time?
March 11, 2025 at 3:26 pm #16802610
My apologies for the misunderstanding, but this is not exactly what I said.
What I said was, that you could try to use a different plugin to create the duplicates of your original product, as each plugin handles this duplication in regards to the translations differently.
This is not something that is controlled by WPML, it depends on the plugin that is creating the duplicates.
March 11, 2025 at 3:47 pm #16802732
ziga pipan
yeah that's what I said also 🙂
I should not duplicate the product with Woocommerce default duplicate option, but I can try with a different one...
March 11, 2025 at 4:12 pm #16802824
Yes, correct. I suggest you try the free plugins Duplicate page and Duplicate Post.
March 14, 2025 at 12:58 am #16814046
ziga pipan
many thanx
