Last updated by vasils 1 year, 2 months ago.
Assisted by: Waqar Ali.
March 19, 2024 at 9:07 pm #15428913
vasils
Hello I am translating this website and run into the problem of this plugin, not showing the translation correctly on the front-end. The strings are from domain elementor-5715 and their titles are: title-heading-2699e3c and
title-heading-9eaf14c
By trying to find information about this I only found
Open …./wp-content/themes/bricks/includes/elements/svg.php file.
Look for line 134.
Replace:
1
$svg_path = get_attached_file( $this->settings['file']['id'] );
With:
1
$svg_path = get_attached_file( apply_filters( 'wpml_object_id', $this->settings['file']['id'], 'attachment', FALSE ) );
Im guessing I need to apply a similar approach to this but I am clueless where to look for in the plugin files. Please assist me in fixing this.
Thank you in advance!
Regards, vasils
March 20, 2024 at 7:20 am #15429582
Waqar Ali
Hi Vasils,
Thank you for contacting us and I'd be happy to assist.
The Elementor header and footer elements can be translated the same way as its other global widgets:
https://wpml.org/documentation/plugins-compatibility/elementor/#translate-elementor-templates
In case the translation doesn't work, I'll need to see how WPML and these Elementor items are set up in the admin area.
Please share temporary admin login details, along with the exact steps to see the issue.
Note: Your next reply will be private and making a complete backup copy is recommended before sharing the access details.
regards,
Waqar
March 20, 2024 at 10:25 am #15430342
vasils
UPDATE: Just found out that the header is a template of Elementor pro, not from this builder... excuse my mistake. I am not sure what is stopping the strings from showing. The string for ОНЛАЙН МАГАЗИН. in the header is also not showing correctly.
March 20, 2024 at 3:30 pm #15432710
vasils
I managed to find the template in translation management. Did not notice there were the templates and translated them automatically. Now it is showing correctly. You may close the ticket
