If you're experiencing issues with Elementor Pro Forms not working on translated pages of your website, while it works in the native language, the issue might be related to a server-side conflict.
We recommend contacting your hosting provider to check if anything on the server side, such as Imunify360 running in kill mode, is blocking outgoing emails or causing issues with form submissions. Additionally, consider using an SMTP plugin to handle email deliveries, which can help bypass server restrictions. You can find more information on setting up an SMTP plugin here: Elementor help on server errors.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
This topic contains 23 replies, has 1 voice.
Last updated by Iris van Zelderen 2 weeks, 5 days ago.
March 9, 2026 at 4:43 pm #17882831
Iris van Zelderen
My client, Match Support BV, has an account with you. Unfortunately, submitting a form created with Elementor Pro Forms isn't working on our website. It works in the native language, Dutch, but unfortunately, submitting the form on translated pages isn't working.
We built it using CPT, with a template that loads on the translated CPTs.
Can you take a look and see why it's not working?
March 10, 2026 at 12:56 pm #17885515
Nigel
WPML Supporter since 02/2016
Hi there
While waiting for a colleague to pick up this ticket, can I request a little more information that may speed things up when they do.
Specifically, could you please clarify how you are translating the template which includes the Elementor form? I ask because we have had some reports of problems when pages with forms are manually translated rather than going through the typical WPML workflow of being sent for translation from the Translation Dashboard. Your issue relates to templates not pages, and the error looks a little different, but it could be related.
The error says there is a server error, which suggests there might be details of the error in the debug.log. Is that active on the site? If not, could you activate debugging and re-test, then share details of any error found?
Depending on what you find, we may need access to the site to investigate, so let me set up a private reply now to get credentials from you, in case they prove necessary. You may want to create a temporary admin user for us to use that you can later delete. And be sure to have a current backup of the site.
Can you also confirm how we can see the problem.
March 11, 2026 at 11:43 am #17888410
Shekhar Bhandari
WPML Supporter since 03/2015
Hello there,
Thank you for contacting WPML support. I'd be happy to assist you on this issue.
It looks like due to the telephone number validations the issue is happening, can you remove the tel number once and see if it helps?
Further, I have created a public test site here: hidden link can you install the elementor plugin and create a similar contact form page to see if the problem is reproduced here?
Look forward to your reply.
March 11, 2026 at 11:59 am #17888444
Iris van Zelderen
Hi!
I tried it but still the same issue.
So can you help me more?
March 11, 2026 at 12:11 pm #17888493
Shekhar Bhandari
March 11, 2026 at 12:25 pm #17888518
Iris van Zelderen
It works on that site, but it works on our site in the Dutch language but not in the other languages. So we have still the problem.
March 11, 2026 at 12:43 pm #17888718
Shekhar Bhandari
Hello there,
To get a better understanding, I suggest sharing a backup of your wp-content folder and your database. You can zip the files and send them to me via Google Drive. With these, I can set up a local copy of your site and take a closer look at the issue.
March 17, 2026 at 4:31 am #17902134
Shekhar Bhandari
Hello there,
I have requested access to the drive. Please let me know when you provide it.
March 17, 2026 at 5:36 am #17902176
Iris van Zelderen
Hi! Yes you have see the files now
March 17, 2026 at 6:08 am #17902287
Shekhar Bhandari
Hello there,
The database backup doesn't have any WPML tables, can you create a new backup and share it, it should be identical to the live site so we can effectively check the issue.
March 17, 2026 at 10:31 am #17903594
Iris van Zelderen
I added one more file from a other database but this are the only one who are in the hosting details add this point.
March 17, 2026 at 11:13 am #17903930
Shekhar Bhandari
Hello there,
I have replicated your site on my localhost and the issue doesn't exists at all making it hard to test further.
On the site, Have you tried disabling all non-WPML plugins, switching to one of the default themes, and checking whether the issue still persists or not?
Please remember to create a backup of your site (both files and the database) before making any updates or changes. This is always a good practice.
March 20, 2026 at 5:00 pm #17914959
Iris van Zelderen
Hi Shekhar,
Yes I tried but then we don't see our vacancies anymore because we created our own CPT. So on you localhost site you can mail on a vacancion on English and Dutch for example?
Can you look at our website with the login I shared? Because then maybe you can help me test is?
Thanks already!
March 20, 2026 at 5:10 pm #17914984
Iris van Zelderen
If I disable only the WPML plugins then it works. So the problem is in the plugin or on the translation of the template, CPT of something else.
Please can you help me?
March 20, 2026 at 5:12 pm #17914988
Iris van Zelderen
Specific in the plugin: WPML Multilingual CMS. Tested with the others that we have for the translation.
