The client has translated headers and footers from Hebrew to English using Elementor. Despite following a tutorial, the original Hebrew headers and footers are still displayed on the English version of the site. The client suspects a conflict between the Hebrew and English templates and is also seeking advice on the compatible MariaDB version for the plugin.
We reviewed the client's site and identified that the header for the English version had not been translated. We recommend translating the header at this link and checking if that resolves the issue. Regarding the MariaDB version, we advise consulting with the plugin support for the exact version required.
Last updated by Kor 1 year, 8 months ago.
November 28, 2023 at 4:38 pm #14942437
ayeletY-2
I translated the headers and footers from Hebrew (the original language) to English.
The header and footer templates have certain conditions for displaying on specific categories, pages, or posts.
I followed this tutorial: https://wpml.org/forums/topic/elementor-template-condition/ but still can't make it work.
The Hebrew (original) headers and footers are still being displayed for the English version. Why?
A hint: when checking the template condition of the Hebrew templates, it indicates a conflict with the English template, which may be causing this issue.
I think I'll need forther help on this one since I did everything I could.
November 28, 2023 at 7:31 pm #14943885
WPML Supporter since 08/2022
Also, I checked your debug information, I noticed that your MySQL version is below the plugin minimum requirements as described at: https://wpml.org/home/minimum-requirements/ . Kindly contact your hosting provider and ask them to update the MySQL version to 5.6+ for you.
November 29, 2023 at 7:22 pm #14955809
Thanks for your reply.
I can see the issue here. hidden link . Upon inspecting, I noticed that you've not translated the header here hidden link , Could you translate it and let me know if this fixes the issue you had there?
November 30, 2023 at 3:13 pm #14964475
ayeletY-2
Wow. Brilliant. That's sort out the issue. Nice catch (and shame on mt)!
Appreciate if you could also adress the MySql version mention above so we can resove this issue completly.
Thanks again Kor.
-Ayla
November 30, 2023 at 3:28 pm #14964635
Sorry, for the SQL version, please contact your hosting provider and ask them to increase the version for you.
November 30, 2023 at 3:37 pm #14964745
ayeletY-2
Thanks again.
Here is what he said:
"You have to check the database version which is compatible with the plugin which requires upgradation or you should consult with the plugin support so they tell you the exact version."
I've attached a screenshot of my host setup on this regard. Please let me know what Maria DB version I should meet.
What version of MySql and MariaDb should I use? Remember, this upgrade is irreversable from the host side. It could be harmful process.
Thanks again,
-Ayla
November 30, 2023 at 3:48 pm #14964897
Ok, that's a version our plugin supports. All good now.
