After duplicating products and importing translated content via WP All Export and Google Sheets, the products still display as duplicates in the admin area with a message indicating they are maintained by WPML. This could potentially overwrite the translations if the original product is edited.
This behavior is expected because WP All Export does not modify the post status in the postmeta table, which means imported products remain marked as duplicates. To resolve this, you can manually set each product to 'translate independently' by clicking the respective button in the WPML interface. Alternatively, you can attempt to remove the
_icl_lang_duplicate_of
keys using WP All Import, which might change their status to independent translations. Detailed steps for this process can be found here. Ensure you back up your site before making these changes.
If this solution does not apply to your situation, or if it seems outdated, we recommend opening a new support ticket. We also advise checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum.
This topic is split from https://wpml.org/forums/topic/automatic-translation-overrides-manual-translation/
Last updated by 7 months, 1 week ago.
Assisted by: Laura.
