Last updated by Andreas W. 3 months, 3 weeks ago.
February 23, 2025 at 6:39 am #16737271
nakulK
I translated my site using WPML, but I am facing an issue with the SEO of the second language links. The site I need help with is hidden link.
I am facing an issue in the SEO of the second language links after translating the site.
How can I resolve SEO issues for the second language links after translation?
February 23, 2025 at 6:40 am #16737287
nakulK
Hi sir
I try to check seo links here hidden link and these gives some errors in specific pages I tried to change url also even but issue is still same
February 24, 2025 at 6:03 pm #16742606
nakulK
is anyone there?
February 26, 2025 at 7:55 pm #16753260
Our apologies for the delay in answering.
I do not see an issue here, as it is expected to have one hreflang for each active language plus one for x-default. See screenshot.
I am sadly not able to see your Spanish website due to a location block.
Could you please clarify what you are expecting to see?
February 27, 2025 at 4:59 pm #16757317
nakulK
Hi sir
here you can use vpn and will be able to see it
for example its working fine but in seopress that have error you can check here in this tool hidden link
February 27, 2025 at 5:00 pm #16757333
nakulK
the issue comes alternate does not link back
February 27, 2025 at 6:06 pm #16757661
nakulK
you can try here
February 27, 2025 at 6:08 pm #16757678
If I switch on hidden link to Spanish I get a 404 error.
It seems like the permalink is not building up correctly. To understand the issue I will need to take a look into the backend.
IMPORTANT
If you cannot see the "wp-admin / FTP" fields, your post and site credentials will be set to "PUBLIC". DO NOT publish the data unless you see the required wp-admin / FTP fields.
Video:
Please note that we are obliged to request this information individually on each ticket. We are not permitted to access any access information that was not specifically submitted on this ticket in the private response form.
February 27, 2025 at 6:50 pm #16757761
The original page uses the slug:
workers-compensation/mtg/hand-wrist-and-forearm-injuries
This is an unexpected slug. I would not suggest building a slug this way.
Go to hidden link
and change the slug to:
The translated Spanish page appears here:
This is expected, as by default WPML will use the title as slug.
Also, take note that the Spanish page is not yet published to Headless Hostman:
"This page has not been published to your live website. Push the red button to get it there, when you are ready."
March 1, 2025 at 8:44 am #16763446
nakulK
Hi sir
thank you for updates here as you can see spanish page is working here in my side also on seo tools that shows main english page is fine but here is issue in spanish page
if you think here is issue in url of site you can suggest me the better one hidden link according to wpml methods
March 1, 2025 at 8:48 am #16763461
nakulK
here I can not see any option for private access
March 1, 2025 at 4:02 pm #16764144
Thank you for your reply.
I can see the language redirect using the language switcher is working now.
Take note:
Your SEO tool is expecting the slug to have a identical structure in the second language, means:
You created a slug for the original page like:
/workers-compensation/mtg/hand-wrist-and-forearm-injuries
Inside WordPress, it would usually expected, that "hand-wrist-and-forearm-injuries" is a subpage of "mtg" and "mtg" is a subpage of "workers-compensation".
In your case, such pages do not exist and I can not suggest that build the slug this way.
Not only because of WPML, but also because this is simply not how slugs work in WordPress.
March 1, 2025 at 5:43 pm #16764296
nakulK
okay got it
so here now what is exact solution for it now sir ?
March 1, 2025 at 6:56 pm #16764399
The solution was already provided here:
I can not suggest creating a slug in this way on the original content.
March 1, 2025 at 8:52 pm #16764557
nakulK
sorry ?
you said provided by here and send me this link
where that is described?
The topic ‘[Closed] facing issue in seo part’ is closed to new replies.
