This topic contains 20 replies, has 0 voices.
Last updated by Kor 9 months, 1 week ago.
April 30, 2025 at 7:36 am
bikbulatovaE
I am trying to fix links that point to the main language on translated website versions. The issue can be seen on this page: hidden link. I expected to see the link hidden link instead of hidden link in the text corpus, and hidden link instead of hidden link in the account button.
I also tried the function "Translate Link Targets" in WPML > Settings.
I am getting wrong links that point to the main language instead of the translated versions.
Why are the links pointing to the main language instead of the translated versions?
How can I fix the links to point to the correct translated pages?
May 1, 2025 at 9:41 am #16986249
Thanks for your patience.
I regret any inconvenience caused, but to proceed with troubleshooting, I kindly ask for a snapshot of the site. Alternatively, with your permission, I can create one myself. For this purpose, I typically recommend using the free plugin "Duplicator." If you're already familiar with Duplicator (https://wordpress.org/plugins/duplicator/), please skip the following steps and simply send me the archive file you downloaded.
May 6, 2025 at 8:09 pm #17003488
bikbulatovaE
You want staging website?
May 7, 2025 at 12:50 am #17003987
Thanks for your reply. A staging site can be helpful too.
May 16, 2025 at 4:03 pm #17042812
Thanks for your reply. It looks like some conflict with another plugin. Could you check now? Switching to another language seems possible now hidden link .
Could you check and see if other links are working correctly for you too?
May 21, 2025 at 8:12 am #17055532
bikbulatovaE
It seems to work, yes.
May 21, 2025 at 11:02 am #17056630
Thanks for your reply. Glad that helped. You can try reactivating the plugins that I've deactivated to see which one is causing the issue you had there.
May 26, 2025 at 2:07 pm #17073743
bikbulatovaE
How can I replicate the fix for the live website?
And this was only for wrong links in menu.
The links in content still need to be fixed.
May 26, 2025 at 2:24 pm #17073999
Thanks for your reply. Could you perform a full backup of your live Website? Then, share your updated credentials here, and I will check further.
May 28, 2025 at 6:56 am #17081394
Thanks for your reply. It looks like RankMath is causing the issue with the broken links. You need to check on that. As for the links on the contact us page, it works now hidden link after changing the slug here hidden link for the German language page.
May 30, 2025 at 5:32 am #17090381
bikbulatovaE
So how should I proceed, disabling rank math isn't an option... Only if temporary.
I don't have this issue on other websites.
And how to proceed with the links, man I cant edit all the slugs one by one, there are still all the wrong links in the product category descriptions.
May 30, 2025 at 8:25 am #17090929
Thanks for your reply. You need to check with Rank Math support to see what's causing this. It's probably some configuration that needs to be adjusted.
June 3, 2025 at 6:53 am #17100176
bikbulatovaE
This is not rank math. The link targets are not translated.
So just to recap:
I disabled rank math then enabled it back and it fixed the bad link routing (links in menu) for translated languages..
Concerning the non-translated links on pages and category descriptions: these links were not translated. So I believe that the automatic translation can't handle it. Could maybe check with your team if all the link translation work?
There is the link replacement funciton in the plugin settings. Could you extend the functions of this tool to check the strings and meta deta also, not only the blog posts?
Because what we are talking are links in individual pages (not blog posts) and links in woocommerce product category descriptions (this is taxonomy).
June 4, 2025 at 5:36 pm #17107758
Thanks for your reply. We've fixed the contact us page internal links earlier here hidden link . So, regarding this "Concerning the non-translated links on pages and category descriptions: these links were not translated.", may I know where I can see this? Perhaps some configurations need to be adjusted.
June 4, 2025 at 6:29 pm #17107913
bikbulatovaE
On all product category pages.
Here for example, down the description > nous avons le tapis en jute parfait pour votre maison.
Same here button down the page for the contact page: hidden link
It's everywhere.
