If you're experiencing issues with the flags not aligning horizontally when using the Twenty Twenty Four theme, you might need to apply custom CSS to adjust their alignment.
We recommend adding the following CSS code to your site to align the flags properly:
.wpml-language-switcher-block ul.horizontal-list > li {
    display: flex;
    align-items: center;
.wpml-language-switcher-block .wpml-ls-flag {
    display: block;
    width: 18px;
    height: 12px;
    margin: 0;
    vertical-align: middle;
.wpml-language-switcher-block li[data-wpml="current-language-item"] .wpml-ls-flag {
    margin-top: 3px;
You can add this code via wp-admin → Appearance → Customize page → Additional CSS.
For more details on customizing the language switcher, check out these documentation links:
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at WPML support forum.
Last updated by Mateus Getulio 1 year, 7 months ago.
Assisted by: Mateus Getulio.
September 16, 2024 at 11:51 am #16183377
stefanE-16
I noticed that the flags do not align when using the default theme Twenty Twenty Four. It looks like I will need to use CSS to adjust.
Flags do not horizontally align when using Twenty Twenty Four - FSE theme. I expected to see that flags align horizontally to each other. Instead, I got not aligned flags.
How can I align the flags horizontally when using the Twenty Twenty Four theme?
Is there a specific CSS code I should use to fix the alignment issue?
September 16, 2024 at 8:27 pm #16185542
Mateus Getulio
Hello there,
Can you please try to add the following code to your site to check if it gets the effect you wanted?
    display: flex;
    display: block;
    width: 18px;
    height: 12px;
    margin: 0;
    margin-top: 3px;
You can add it to wp-admin → Appearance → Customize page → Additional CSS.
Please check more about language switcher customization:
https://wpml.org/documentation/getting-started-guide/language-setup/language-switcher-options/how-to-fix-styling-and-css-issues-for-the-language-switchers/
https://wpml.org/documentation/getting-started-guide/language-setup/language-switcher-options/how-to-display-or-hide-the-language-switcher-on-specific-pages/
September 20, 2024 at 10:54 am #16202464
stefanE-16
Thank you the CSS worked nicely!
I noticed when doing an inspect element that there are some alignment issues with the flags. It would be helpful to get alignment in place so that I do not need to use this CSS in the future to align the flags.
Thank you!
