[Resolved] Footer widget string translation not showing up on front end
If you're experiencing issues with the footer translation not appearing on the front end even though it's translated in the string translation table, and the widget content translates fine but the titles do not.
This is a compatibility issue. Adding the following language configuration code in WPML>>Settings>>Custom XML Configuration has fixed the problem.
I am trying to translate my site to Arabic, but the footer translation won't show up on the front end no matter what I try. It is translated in the string translation table (see photo). The widget's content translated fine, it seems to be the titles that are the issue.
I tried clearing the cache, deleting the strings, and translating them again but still had the same issue.
Please visit WPML>>String Translation after a site backup{mandatory} and enable the *Look for strings while pages are rendered* option of *Auto register strings for translation* section(on the bottom of the screen). Then visit the frontend pages and check whether the issue exists or not. This option will be disabled in a couple of hours automatically. But will help us to track the issue in similar cases.
2) Increase the *MaxInputVars* of PHP settings to *10000*. Please check the following article for more details and contact your system admin/hosting provider to upgrade this configuration.
Thank you for the updates. Please fill the private details fields after a full site backup. I would like to access the admin area of your site for further checking. Refer to the following links for more details about our private information sharing policies.
Thank you for the login information. The Footer widget strings are showing the translation after adding the following language configuration code in WPML>>Settings>>Custom XML Configuration.
