The client is experiencing an issue where the header on the Swedish version of their website does not function correctly.
We discovered that the problem is due to custom JavaScript code in the header. We recommend removing this module JS code and instead adding it to the theme's options. Specifically, navigate to Divi > Theme Options > Integration and add the code to the
<head>
of your blog. This adjustment should resolve the issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking for related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should the problem persist, please do not hesitate to open a new support ticket with us for further assistance at WPML support forum.
This topic contains 1 replies, has 2 voices.
Last updated by 1 year, 9 months ago.
Assisted by: Long Nguyen.
