You are trying to translate your BetterDocs documentation from Danish to English, but you're facing an issue where headers such as H2, H3, and below are not visible on most translation pages, although they appear on some.
We recommend two approaches to resolve this issue:
1) Modify the string format by removing the dot after the numeral in your headers. For example, change from (2.1. Økonomi) to (2.1 Økonomi). This adjustment should make the headers visible in the translation editor.
2) Utilize the search field in the translation editor to locate and translate these headers.
If this solution does not apply to your case, or if it seems outdated, we encourage you to open a new support ticket. We also highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by henrik-normannN 1 year, 1 month ago.
Assisted by: Osama Mersal.
January 18, 2025 at 7:55 pm #16609752
henrik-normannN
Site owner
I'm trying to translate my BetterDocs docs from Danish to English. The issue can be seen on this page: hidden link.
I expected to see H2, H3, and below on the translation page, but they are not visible for most posts. However, it worked on this one: hidden link.
Why are the headers not showing up for translation on most posts?
Why does the translation work on some posts but not others?
January 19, 2025 at 9:00 pm #16611248
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
Thank you for contacting WPML support. While you wait for one of my colleagues to take this ticket and work on it, let me provide you with the first debugging steps or see if I can help with the issue quickly.
I can see H2 and H3 titles on the page you sent as an example. Please see the attached screenshot. Design-wise, the English page looks the same as the original Danish page.
Have you solved this problem already?
If not, please elaborate on this problem and send us screenshots.
Itamar.
January 19, 2025 at 9:21 pm #16611268
henrik-normannN
Site owner
Not solved, we use some english terms in danish. The problem is still that WPML doesn't always find the headers. If you look at the table of contents, it's in danish. Looking at the WPML translation it does show some of the headers, but where I'd expect the "2.1. Økonomi" header from image 1 it doesn't appear. I've attached an extra image from BetterDocs, so you can see how it's setup. It should be a H2 header, so it clearly exists on the page, but WPML overlooks / doesn't find it.
It has happened on most of my docs, except the previous exception I linked, which I setup excatly like the rest. So I'm quite puzzled.
January 20, 2025 at 3:05 pm #16614108
Osama Mersal
I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
Osama
January 21, 2025 at 8:55 am #16616834
Osama Mersal
1) Thanks for your reply. Please check the provided access details.
2) No need for FTP now. I'll check the issue, and if it's needed, I'll let you know.
3) The "All-in-One WP Migration" plugin is perfect for taking a site backup.
Osama
January 21, 2025 at 10:35 am #16617777
Osama Mersal
Thanks for the access details. I checked the issue, and there are two workarounds for this case:
1) Change the string from (2.1. Økonomi) to (2.1 Økonomi) without the dot after 1.
After this change, you will be able to see the heading in the translation editor.
2) Use the search field in the translation editor to translate these headings. (Kindly check the attached screenshot)
Osama
January 21, 2025 at 6:32 pm #16620180
henrik-normannN
Site owner
I can confirm your solutions worked. Many thanks for the help, it's been much appreciated.
