The client is experiencing an issue where a plugin is incorrectly translating documents on a multilingual site managed by WPML. The English page displays 145 documents in both English and French, but the French page does not display any documents due to a translation conflict.
We do not have a specific setting in WPML to prevent the translation of these documents. Instead, we have set up a sandbox environment for the client to reproduce the issue with the same plugin configuration. This step is crucial to determine if the problem can be confirmed as a bug. If the issue is reproducible, we will involve our compatibility team and possibly the plugin authors to investigate and address the issue. The sandbox can be accessed here: https://grey-synthesizer.sandbox.otgs.work/?auto=NrvRBvvYq5uIvwEWFwk4XzjO3UH1VquU.
Please note that if this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket for further assistance at WPML support forum.
This topic contains 20 replies, has 0 voices.
Last updated by abchimieP 2 weeks, 6 days ago.
Assisted by: Marcel.
| Author | Posts |
| March 5, 2026 at 7:50 pm #17876251 | |
abchimieP |
Hi, |
| March 6, 2026 at 10:44 am #17877507 | |
Marcel Supporter
Languages: English (English ) Spanish (Español ) German (Deutsch ) Timezone: Europe/Vienna (GMT+02:00) |
Hi, Are the documents set up as a Custom Post Type (CPT)? If so, you can configure the CPT to use a fallback language, which will display the original version whenever a translation is not available. If the documents are part of the regular content, they need to be translated accordingly. Skipping them isn’t how the system is designed to work. The only exception is if you duplicate them as a translation in Translation Management, which allows the original content to appear in other languages until a proper translation is created: The "fallback" can be configured as described here: https://wpml.org/documentation/getting-started-guide/translating-custom-posts/#cant-find-your-custom-post-types Best regards, |
| March 7, 2026 at 12:09 am #17878739 | |
abchimieP |
Still doesnt work.... these are PDF documents created to be listed please see page hidden link the same list of documents in both languages should be showing on the french page hidden link. doesnt show the list.. its creating conflict I contacted the plugin support from that listing page and they said that it is a conflict with WPML, as before I installed the WPML page, it was showing the same list on the french page. Please help find a solution here |
| March 9, 2026 at 9:07 am #17881103 | |
Marcel Supporter
Hi, I would eventually also need to request temporary access (WP-Admin and FTP) to your site Your next answer will be private which means only you and I have access to it. ❌ Please backup your database and website ❌ ✙ I would additionally need your permission to de-activate and re-activate Plugins and the Theme, and to change configurations on the site. This is also a reason the backup is really important. ✙ Please add the Links to the […] Edit Screen, the Page/Post where you insert the […] and the corresponding Front End Page/Screen Best Regards, |
| March 13, 2026 at 2:37 pm #17895960 | |
Marcel Supporter
Hi, This is not really a conflict, this behavior is expected. You have a piece of content (page, post, document, or any other custom post type), and WPML expects a translated version of it, since it tries to load the translated database ID for that content. Have you tried configuring the custom post type to use "fallback" to the default language? At the moment it is not enabled: You can also duplicate all existing posts to French via Translation Management. Currently, there are no translations saved. Could you please confirm that you have tested those options? Best regards, |
| March 13, 2026 at 4:15 pm #17896420 | |
abchimieP |
I have changed as per described above... I spoke to the Document Library app support and they said the problem is with WPML, it shouldnt force translate the app information documents Please help me find a solution it has been more than 2 weeks with this issue. All I want is for WPML do not translate the plugin content lists and leave both languages the same with the 145 documents lists to be reach on both pages. hidden link and hidden link. But I see the menu from English to french is not syncronizing only that speciafic page hidden link. and when I am on the french page it appears only french flag as before used to be 2 flags Please help me find a solution, I have already grant access as Admin for you to work on it, I am tired of trying different things and do not see any changes thanks for now, |
| March 13, 2026 at 5:00 pm #17896475 | |
abchimieP |
I have had probolems with my domain... and reported that to Hostinger. They replied: The domain switch likely happened because someone changed your WordPress Site URL/Home URL settings or ran a search/replace for the preview domain. This can occur during site migration, plugin updates, or manual edits. p-lease DO NOT CHANGE MY Domain abchimie.com to run any tests.... your colleague from WPML did help me in the past without any issues. |
| March 16, 2026 at 2:31 pm #17900968 | |
abchimieP |
Could someone assist me here please?? I am struggling to get the right support |
| March 16, 2026 at 3:16 pm #17901160 | |
Marcel Supporter
Hi Elisangela, Thank you for your message. Unfortunately, the explanation you provided is still a bit unclear to me.
Our plugin is designed to enforce translation of content, as this is the expected behavior of a translation plugin such as WPML or similar tools. The only way to exclude specific content from translation is the method I mentioned earlier, by adjusting the Custom Post Type translation settings. So far, I have not received clear confirmation on whether this change was applied, or what exactly did not work on your side. Could you please confirm if you also tried the duplication workflow I described in my previous message, and what result you got?
Could you clarify what exact issue you experienced with the URL change? Modifying the site URL would normally require either direct server/SSH access or the use of a search-replace plugin, and neither of these actions were performed (no server access). Was a resave of the permalinks performed by any chance? This could also trigger URL-related changes in some cases. I tried to check your settings but the credentials are not active anymore. Best regards, |
| March 17, 2026 at 9:24 am #17903179 | |
Marcel Supporter
Hi Elisangela, Thank you for the information and for creating the new user account. We did not change any URLs. Without SSH/FTP access, the only way to modify URLs would be by overwriting the values under **Settings → General**, which would not make sense in this case and was not requested, nor we need that for WPML. There was no need to change any URLs, so it is likely that something else caused the issue. Unfortunately, I do not have enough information at the moment to determine exactly what happened. Regarding the information you received from the Document Library App support: this does not seem to apply to your situation, so it does not help us find a solution. Your use case is different. In your setup, page translations are effectively being forced because translation was not disabled in the Post Type settings, as I described earlier. Since the plugin is designed to work this way, it is difficult to provide a correct solution if we rely on guidance that does not match this type of configuration. At the moment, the CPT translation is disabled. On the page in question, the shortcode `[doc_library]` is added without any filtering for specific content, and the same shortcode is used on the translated page. With translation disabled in the CPT settings, no translation should be active, yet the output is still different. I changed the CPT setting to **fallback** and verified that there is no French translation present (it shows 0). The output is still identical, which indicates that the issue is not caused by the translation settings. However, I noticed something important while checking your setup: This means you do not actually have a translation for that page. Instead, you currently have two separate entries in the database. The original French page appears to be in the trash: Please restore this page so we can test again. It seems there was a misunderstanding, and the content at This also explains the menu issue you mentioned: > Currently, I am also noticing another issue: the language menu is not synchronizing correctly on the French page (hidden link). When accessing that page, only the French flag is visible, whereas previously both language flags were displayed. This behavior is expected because the pages are not linked translations but two separate entries. Please restore the deleted page and let me know once this is done, then we can continue testing the Document issue, as the frontend output might change then already. Best regards, |
| March 17, 2026 at 10:50 pm #17906034 | |
abchimieP |
Hi Marcel, thanks for your support... I have done as per your instructions and the page is restored and activated so was automatically the Menu sync English-French. All sorted BUT, only one thing missing which I believe it is to do with WPML. Please see screenshots of French and English pages. The product list on the French page is missing The product list on the English page is showing What coudl be the mistake?? I tried to check everywhere I can't find why... This is not the plugin library document... it is more to do with WPML settings on that specific space? Appreciate your help on this matter, the ID and PW to access the site remains still the same, appreciate your support to finalise this last task. Best regards, |
| March 18, 2026 at 3:06 pm #17908609 | |
Marcel Supporter
Hi Elisangela, There isn’t a specific setting to control this. In this case, WPML isn’t displaying a translation—it simply loads the content from the original CPT. I’ve set up a sandbox environment where you can reproduce the issue. Please install the Docs plugin here: Then try adding 1–2 entries with the same configuration. Are you able to reproduce the issue? If so, I’ll forward this to our compatibility team. They may also reach out to the plugin authors if any changes are needed on their side. Best regards, |
| March 20, 2026 at 12:06 pm #17913860 | |
abchimieP |
Hi Marcel, thanks for your reply. Unfortunately I wont be able to install the plugin as it is a paid version and only works with the keycode. Would you please contact the plugin support? I have been in communications with them on : support+canned.response@barn2.com Plugin Support Request - Document Library Pro Their support asked me this: Hello Elisa, Could you please share the response from the WPML team regarding the issue with the titles? |
| March 20, 2026 at 12:40 pm #17914032 | |
Marcel Supporter
Hi, Sorry, but we can’t provide support outside of this public forum. Please feel free to send them the Sandbox link so they can install a key there. Best regards, |
| March 23, 2026 at 9:59 am #17917649 | |
abchimieP |
Hi Marcel, this is the Barn2 Support reply: Hi Elisa, I’m not entirely sure but If the suggestion is to add our own license, I’ve already tried that but still can’t get the setup working. Here’s what I’m seeing: hidden link I also attempted to log into our WPML account, but the email doesn’t seem to be recognized, so we’ll need to look into that separately. |
