Problem: The client is experiencing issues with ACF fields not maintaining consistent category assignments across different languages in a WPML environment. Specifically, when adjusting categories in one language, they appear random or default to the first alphabetical categories in another language. Solution: 1. Ensure all categories are correctly translated under WPML > Taxonomies translation. 2. In the default original language, adjust the field group's settings to have "identical fields on all languages". 3. Create a new post or page and assign it to one of the categories listed in the ACF group configuration. Save and check if the field displays on the original language post. 4. Duplicate or translate the post to a second language and verify if the fields are visible and if the correct category is assigned. If these steps do not resolve the issue, we recommend trying to replicate the issue on the provided sandbox environment. Additionally, please ensure that you have the latest versions of all themes and plugins installed. If the problem persists, it might be due to an outdated solution or a different issue. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix. If necessary, please open a new support ticket at WPML support forum for further assistance.
Languages: English (English )French (Français )Arabic (العربية )
I would like to ask for temporary access to your staging site’s wp-admin and FTP to investigate the issue further.
Kindly provide me with the steps on how to replicate the problem.
It is important to note that you should back up your site and database before proceeding, and you can use a plugin like Duplicator for this purpose. Here’s a link to the plugin: http://wordpress.org/plugins/duplicator/
If you do not see the form below, please do not enter your credentials, as they will be publicly exposed:
For your privacy and security, please ensure that you make your reply a private one.
So i was able to replicate the issue on one of our sandbox environments : hidden link
I have recorded a video explaining this behavior : hidden link
Basically, you are not supposed to change the editing language on ACF fields, even if you do so, WPML will only take into account the last setting you saved regardless of the language,
But as a recommendation, always edit your ACF fields in one language if possible,
It could be confusing of course seeing different settings, but at the end, WPML only takes one language settings and apply it to the other in the background (on the post creation level)
If you think this should be improved, I could escalate the matter to our development team and find a permanent solution for it,
My issue is that if i go on the english translation for the article, that field doesn't show up.
What we are trying to achieve is having fields in both languages and having the content of the italian fields carry over but still be editable so that whoever is filling the translation doesn't have to fill fields that are already multilanguage.
to achieve this we set up the translation to expert and selected the "copy once" option for the fields themselves.
we have now ran into this issue tho.
as you see, in italian - works
in english, missing
everything is set as
any idea how to make this work the way we are expecting it to work?
are we setting it wrongly?
Ilyes is absent today, so I'll be responding on his behalf. I've read through all the details of the ticket, so we can pick up where he left off 🙂
Could you try again with a test post using the "copy content from $language" option? Perhaps with the new settings, the behavior will be different.
If it still doesn't work, I ask that you review the access to the staging version you provided. I tried accessing it to test, but I encountered a 500 error.
Nothing changed from the previous behaviour - as Ilyes suggested we'd like to suggest changing the way WPML handles category filters in ACF, at least when the "expert" option is selected;
It should save filters *per language* and not as it's doing right now which is a mixup and is not working properly.
We found a workaround by duplicating an article, changing the language and linking the translation manually so we'll go ahead with that.
