The client is building a multilingual website using ACF and Bricks Builder and has encountered issues where the Bricks design is not loaded into the newly made page in other languages. Additionally, they are experiencing unwanted automatic translations.
To resolve these issues and set up the website as before, follow these steps:
1. To disable automatic translation, navigate to WPML > Translation Dashboard and pause the 'Translate everything' mode.
2. From the same dashboard, go to the Jobs tab and cancel any ongoing translation jobs.
3. Edit your ACF field group and at the top, select 'Different fields across languages' to ensure correct translation settings. For more detailed guidance, visit Translate sites built with ACF and Recommended custom fields translation preferences for ACF and WPML.
4. To manually translate pages, edit your default language page, switch to the WordPress editor, and make this change permanent for pages or all website content. For more information, visit Using different translation editors for different pages.
5. Ensure you also translate other relevant content such as templates or menus.
If this solution does not resolve your issue or seems outdated, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If problems persist, we recommend opening a new support ticket for further assistance.
Last updated by Dražen 1 week, 1 day ago.
Assisted by: Dražen.
September 16, 2025 at 8:47 am #17404998
martM-6
I'm building a multilingual website (NL, DE, EN) using ACF and Bricks Builder. In the past, I've used WPML with a workflow where I create a translated version of the page via the gear-icon/flag and insert different content in the ACF Fields.
When I try this now, my Bricks design is not loaded into the newly made page. I also get spammed with auto translation, but we translate the website ourselves.
Could you help me set this up like before?
Could you tell me what I'm doing wrong?
September 16, 2025 at 1:02 pm #17406248
Dražen
thanks for contacting us.
Let me try and help you out, please follow next steps:
1) To stop automatic translation, go to WPML > Translation Dashboard and click to pause Translate everything mode.
2) From WPML > Translation Dashboard, go to Jobs tab and cancel any ongoing jobs.
3) Go and edit your ACF field group and at the top select Different fields across language. This will auto set correct translation settings for your fields and you should be able to adjust it. You can also go with Expert mode, just make sure to adjust correct translation settings.
- https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/
- https://wpml.org/documentation/related-projects/translate-sites-built-with-acf/recommended-custom-fields-translation-preferences-for-acf-and-wpml/
4) To translate pages manually, edit your default language page, and click to switch to WordPress editor, then choose to make this switch permanent for pages or all website content.
- https://wpml.org/documentation/translating-your-contents/using-different-translation-editors-for-different-pages/
You can now duplicate page to 2nd language, and then adjust and translate your 2nd language content manually.
5) Make sure to also translate other relevant content, like templates, or menus etc.
Let me know how it goes.
Drazen
