You are trying to translate Bricks Builder pages and some Custom Post Types (CPT) created with JetEngine, but the design of the Bricks Builder pages disappears, and you are unable to find some meta fields in the translated version.
For the issue with Bricks Builder pages losing design upon translation, please refer to our Errata page for a known issue and workaround: Bricks translated content not showing on frontend.
To translate shortcodes from the translation editor, you need to register the shortcode for translation. Follow the guide here: Translate custom shortcodes with WPML.
For translating JetEngine meta fields, navigate to "WPML > Settings → Custom Field Translation" and set the translation preference for those fields to 'Translatable'. For more details, check the Crocoblock guide: Translate Meta Boxes & Meta Fields.
If you encounter issues translating the ID within a shortcode, use the String Translation to translate the entire shortcode. Navigate to "WPML > String Translation", search for the shortcode, and update the ID for translation as needed.
If the solution provided here does not resolve your issue or seems outdated, we recommend opening a new support ticket. Also, check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum: WPML Support Forum.
Last updated by Prosenjit Barman 1 year ago.
June 4, 2024 at 1:27 am #15699549
sebastianS-125
I try to translate my Bricks Builder pages and some CPT created with Jetengine on my site hidden link. I am not following any specific documentation, just clicking the plus/gear icon to translate.
Here is a video showing you all visually: hidden link
The design of my Bricks Builder pages is always gone, and I have to start from scratch. I also have problems translating some meta fields for the CPT; I can't find them in the translated version.
How can I translate my Bricks Builder pages without losing the design?
How can I translate meta fields for CPT created with Jetengine?
June 4, 2024 at 11:10 am #15701670
Prosenjit Barman
WPML Supporter since 03/2023
Hello There,
I checked the video and understood the issue. Below, I've added a probable solution for both issues mentioned in the video.
Contents and layout are not showing on the Translated page: We are aware of an issue with the Bricks builder which is similar to the one that you have reported. Please check this Errata for more details.
Would you please try the workaround mentioned in the errata and see if that helps solve the issue?
Shortcode not showing in the Translation editor: To be able to translate shortcodes from the translation editor, it is required to register the shortcode for translation. Please check this guide to understand the process.
The shortcode attribute should appear in the editor after adding the translation support properly.
Regarding the issue you mentioned about translating JetEngine meta fields, you'll need to navigate to "WPML > Settings → Custom Field Translation" and ensure that the translation preference for those fields is set to 'Translatable'. If the fields are not set as translatable, the field data will not appear in the editor for translation.
There is a guide by the Crocoblock team that covers the overall process. Please check hidden link">this guide and I hope it will help.
Please feel free to let me know if you need any further assistance or clarification. I will be happy to help.
Prosenjit
June 9, 2024 at 9:38 am #15719165
sebastianS-125
First of all, sorry for the delay...
I've been reading all the articles and links you sent me.
But I am still not able to translate the shortcode in my CPT, I enabled it in the WPML Settings and also added the script to my functions.php file to translate the ID in the shortcode, but both are not working.
May you can help me with this?
How to translate a shortcode or the ID in the shortcode for a CTP?
Quick summary video for you:
June 10, 2024 at 5:39 am #15720132
Prosenjit Barman
Hi There,
Thank you for sharing the video.
If you open the 'Trustpilot(DE)' post from the Review Platform post type, do you see any field where you can update or change the ID? If such a field exists, you need to find the name of the field containing the ID and set that field to translatable from WPML > Settings. Since you've set a constant to translate the numbers, it should appear in the translation editor only if you search for the ID, not by its field name.
However, if the ID is dynamically inserted into the shortcode, it might not be possible to translate it from the Translation Editor. In this case, you may need to use String Translation to translate the shortcode. Please try the following steps:
- Please go to "WPML > String Translation".
- Search for the entire shortcode.
- If it appears in the results, click on the "+" icon below the language flag.
- Copy the default shortcode and paste it into the Translation box. Update the ID for translation as needed.
I hope it will help. Feel free to let me know if you need further clarification or assistance in this matter. I will be happy to help.
Prosenjit
June 10, 2024 at 9:39 am #15721053
sebastianS-125
I opened the 'Trustpilot(DE)' post from the Review Platform post type, and see no field where I can update or change the ID.
Such a field exists, but I don't find this meta field neither in the translation list by default (after enable the meta field) nor by searching it through the search option.
In the attachment, you can see that this field is enabled to be available for translation.
When I search for the ID, I also don't find anything in the editor, 2 image in the attachment.
The option with the string Translation also doesn't work, see also attachment 3 and 4
Can you tell me another option, or do you want access to the website?
Thanks in advance
June 11, 2024 at 4:45 am #15724419
Prosenjit Barman
The ID appears to be entered dynamically in the shortcode. This is why you don't see any field to update the shortcode or ID. Since the shortcode is not showing in the String translation, have you added the shortcode to any post or page? If not, please add the shortcode and then check again in the String translation. If the shortcode is still not showing in the String translation, plugin scan should help in this case.
- Please go to WPML > Theme and Plugins Localization
- Select the Social Ninja plugin or the plugin that generates the Shortcode and click on the Scan button at the end.
- Once the Scan is completed, go to "WPML > String Translation" and search for the Shortcode again.
If you still don't see the shortcode. a closer inspection will be required to understand the root cause.
IMPORTANT
Best Regards,
Prosenjit
June 11, 2024 at 9:15 pm #15729023
sebastianS-125
I have been able to solve it with a workaround.
Thanks for your effort and help.
