The client is experiencing PHP warnings related to the
simplexml_load_string()
function in the WPML plugin's class-wpml-tm-xliff-reader.php file. These warnings include parser errors such as 'Opening and ending tag mismatch' and 'Sequence "]]>" not allowed in content'.
We recommended the following steps:
1. Increase the WordPress memory limit to at least 128MB, as per our minimum requirements. This can be done by adding the following line to the wp-config.php file:
/* Memory Limit */<br />define('WP_MEMORY_LIMIT', '256M');
Place it above the line /* That's all, stop editing! Happy blogging. */.
2. For issues related to product author and attributes, follow the steps described in our guide on how to correctly import taxonomies and their translations. You can find the guide here: https://wpml.org/documentation/related-projects/wpml-export-and-import/
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If further assistance is needed, please open a new support ticket at WPML support forum.
This topic contains 21 replies, has 0 voices.
Last updated by Carlos Rojas 6 months, 1 week ago.
Assisted by: Carlos Rojas.
October 2, 2025 at 12:52 pm #17452130
bojanN-2
I am experiencing issues with my WordPress site at hidden link while using the WPML plugin. I am trying to resolve PHP warnings related to the simplexml_load_string() function in the WPML plugin's class-wpml-tm-xliff-reader.php file.
PHP Warning: simplexml_load_string() function is generating parser errors, including 'Opening and ending tag mismatch' and 'Sequence ']]>' not allowed in content'.
October 2, 2025 at 12:59 pm #17452150
Carlos Rojas
WPML Supporter since 03/2017
Thank you for contacting us
I kindly request that you describe the steps to reproduce the issue on the site. In other words, when does this problem appear? Also, please share the original error message so we can gather more information to work with.
Carlos
October 2, 2025 at 1:16 pm #17452227
bojanN-2
{"downloadUrl":"https:\/\/ate-production.s3proxy.wpml.org\/translated_xliffs\/xliffs\/114\/556\/191\/original\/translated_160251343_Naslovna20251001-10097-1vnxdp.xliff20251002-13546-1i01v39.xliff?Expires=1760015624&Signature=bMiswQTd0if8s2vuYshQ7qpqrZS8CJ-eMJB5doHatB7kLfhk3P1N4kAZjrSRpERCzYaw0pSX0pLzTxUsYbMUwlz92N54kdn8thxsRxCSefLERugp30LgWOqPHKC3Q6fQZlwzZzz7mMn-K96HhUswmMjlAfpHtp3vlHdVrKTvnrj6cQIL-3dRrSVTsV97x0i~BktaiW~k1mrGaQ7VdW5gLm~fnROncp~nNAmo6VZpBAho4SCphEJSi93JKqFFE6WPN9yGwXXNe-6WriUpZsWhYpyB7FOYt5VsSZOYT01F7zw58fXWnP13ue7wFvwBgyp2k29lzROQD7ltyP1BS1~Sjg__&Key-Pair-Id=K1C11UVRQNXLRQ"}
October 3, 2025 at 8:12 am #17453762
Carlos Rojas
1.- Please describe the steps to reproduce the issue on the site.
2.- Share the site debug information in your next message as described in this guide: https://wpml.org/faq/provide-debug-information-faster-support/
October 3, 2025 at 6:44 pm #17455222
bojanN-2
The problem is that on the single product page, the product description throws errors every hour, but this is not visible on the frontend.
2. [REMOVED]
October 6, 2025 at 9:32 am #17459116
Carlos Rojas
Thank you for sharing the debug information
1- Please increase the WP memory Limit. Minimum requirements are 128Mb: https://wpml.org/home/minimum-requirements/
You can add this to wp-config.php to increase WP memory:`
/* Memory Limit */
You can double-check the WordPress memory limit in WPML -> Support
2.- Also, share a URL where the issue can be seen. You can attach some screenshots or share a link to a video reproducing the problem. This way, we can see the problem clearly and follow the same steps on our side.
October 9, 2025 at 8:21 pm #17472954
bojanN-2
[09-Oct-2025 20:17:23 UTC] PHP Warning: simplexml_load_string(): ^ in /home2/antikvar/dev32.antikvar.rs/wp-content/plugins/sitepress-multilingual-cms/classes/xliff/class-wpml-tm-xliff-reader.php on line 21
October 10, 2025 at 9:31 am #17473988
Carlos Rojas
Please answer the question in my previous message.
October 10, 2025 at 3:14 pm #17474988
bojanN-2
The CPU resources on the server itself are very busy.
October 11, 2025 at 6:25 pm #17476702
bojanN-2
I can't link attribute translations from two other languages. For example: Author in Serbian, when importing it automatically creates it in English as well. ATTRIBUTE AUTHOR
October 13, 2025 at 9:57 am #17479071
Carlos Rojas
Please share a URL where the issue can be seen. You can attach some screenshots or share a link to a video reproducing the problem. This way, we can see the problem clearly and follow the same steps on our side.
October 13, 2025 at 12:22 pm #17479551
bojanN-2
Development site on the address dev32.antikvar.rs. Access to the site is at [REMOVED]
October 13, 2025 at 12:31 pm #17479577
Carlos Rojas
You haven't answered any of the questions I posted. We can't solve the problem if you don't cooperate.
October 13, 2025 at 1:23 pm #17479869
bojanN-2
I recorded a recording of the problem I have. The link to the recording is hidden link 2025-10-13 151534.mp4
October 13, 2025 at 1:24 pm #17479875
bojanN-2
