Last updated by Mateus Getulio 1 year, 12 months ago.
Assisted by: Mateus Getulio.
June 9, 2023 at 4:57 pm #13801393 | |
tommasoC-8 |
hello, i have a website with impeka theme and elementor page maker. i have a problem with seo. Installed wpml with wpml for seo add on. In google i find "var wpml_browser_redirect_param ..." as pace description on english pages. I do not understand what's happening. (website: hidden link ) hidden link |
June 9, 2023 at 9:27 pm #13802241 | |
Mateus Getulio Supporter
Languages: English (English ) Portuguese (Brazil) (Português ) Timezone: America/Sao_Paulo (GMT-03:00) |
Hi, I have escalated this ticket to our 2nd tier of support where our 2nd tier specialists will take a deeper look at this issue and will try to find a solution. I will get back to you as soon as I get an answer from them. Best regards, |
June 12, 2023 at 1:02 pm #13809927 | |
tommasoC-8 |
Salve, come segnalato in chat con il vostro supporto internazionale ho dei problemi di conflitto con wpml. Il sito è hidden link . Sul sito è attivo il riconoscimento automatico della lingua. Il sito contiene circa una 50 di magine ricche ci contenuto, in doppia lingua. Google fatica ad indicizzare le pagine e nella ricerca, inpostando "Tipic" come chiave il risultato descrittivo delle pagine del sito sono stringhe di configurazione di wpml o indirizzi interni di plugin. Wpml, Yoast, Elementor, Impeka, sono tutti installati in versione professionale con licenza. [debug info removed] |
June 12, 2023 at 2:30 pm #13810633 | |
Hey there, Thanks for your reply. May I kindly ask you to keep the communication in English? Unfortunately I cannot properly read and write in Italian. Upon further inspection, we have checked that there is no JavaScript in the source page. In the chat we have disabled the browser redirection, but we still can see the JS in the search result for this page hidden link This is only possible when the JS code is rendered as text. Generally this happens with broken tags. Having this in mind, we checked the markups in a HTML validator hidden link, and found the whole body tag is messed up, please take a look on this screenshot: hidden link Therefore, I'm afraid that the fix for this would be necessary to be configured with some code customization. At this point, it is beyond the scope of this support forum but we recommend that you check our contractors page: https://wpml.org/contractors/. Basically, you should correct the broken HTML tags, and then try another reindex. It should be solved after these steps. Note: the possible solution provided is to be used just as an informational one. Please remember that custom coding is out of the scope of our support, so we can't create, debug or modify code for you and it's your responsibility to maintain it. We hope the one we used as an example could point you in the right direction. Please check our support policy: https://wpml.org/purchase/support-policy/ Thanks for your understanding. If you need anything else don't hesitate to contact us. |
