Last updated by Mohamed Sayed 1 year, 9 months ago.
Assisted by: Mohamed Sayed.
September 24, 2023 at 11:29 am #14452299 | |
deshnav |
I update text on a page, but do not see the edited text in the translation editor. |
September 25, 2023 at 10:11 am #14456823 | |
Mohamed Sayed |
Hi there, Please try to force another translation's update with the following steps: - Complete the current translation If that didn't help, make sure that you have a full backup of the database and website then go to WPML > Support > Troubleshooting page, and click the following: - Clear the Cache in WPML Once that's done, update the original page again and check if you can see those changes in the translation editor. Let me know please if that helps. Kind regards, |
September 25, 2023 at 2:01 pm #14459303 | |
deshnav |
Hi, I did all the steps you mentioned here. And now the translation edit is not working at all. |
September 25, 2023 at 3:26 pm #14460113 | |
Mohamed Sayed |
Hi, 1. Please send me a link to the page where made those changes, also tell me which texts you didn't see in the translation editor. 2. I would need to request temporary access (WP-Admin) so I can investigate this issue further. Your next answer will be private, which means only you and I have access to it. ❌ Please backup your database and website before providing us with access details ❌ If you don't see the form below, please don't add your credentials as they will be publicly exposed: Privacy and Security when Providing Debug Information for Support: |
September 25, 2023 at 3:53 pm #14460377 | |
deshnav |
Hi Mohamed, I have been trying to deactivate various plugins to see if there is a conflict. Thanks for your help, Deshna |
September 25, 2023 at 4:22 pm #14460785 | |
Mohamed Sayed |
I checked the known issues between those plugins and WPML, but I couldn't find any similar issues with the translation editor. There is only one known issue with Litespeed related to the categories that are not synchronized - https://wpml.org/plugin/litespeed-cache/ For Rank Math, there are multiple known issues but none of them is related to showing a blank ATE page. You can check the full list of known issues here: https://wpml.org/plugin/rank-math-seo/ Rank Math requires having the "WPML SEO" glue plugin for full compatibility (https://wpml.org/documentation/plugins-compatibility/optimize-multilingual-websites-using-rank-math-and-wpml/) but I can't see it in the list of your plugins. Please install it from the downloads page https://wpml.org/account/downloads/ or from Plugins > Add New > Commercial tab, then clear the cache and check again if you can access the translation editor while the mentioned plugins are enabled. |
September 26, 2023 at 11:34 am #14466515 | |
deshnav |
Thanks, It looks like the SEO plugin solved the issue. Thank you so much for your help. I think I did not do my research on this so I appreciate you pointing me in the right direction. |
