Last updated by Waqas Bin Hasan 1 year, 5 months ago.
Assisted by: Waqas Bin Hasan.
July 2, 2024 at 7:33 am #15873135
deepsonT
I need help about the WPML currency switcher. I'm trying to add flags to WPML currency Switcher. This is done. But after adding the flags, the currency click is not working properly. Some areas the click is working, but the flag and currency code are not clickable. I tried this code: ' %code%')); ?> to the currency switcher. After that, the currency is not clickable.
The currency click is not working properly after adding flags. Some areas are clickable, but the flag and currency code are not clickable.
Can you please have a look and fix the issue with the WPML currency switcher not being clickable after adding flags?...
July 2, 2024 at 9:27 am #15873836
Waqas Bin Hasan
WPML Supporter since 05/2014
Reference to our recent chat, I was able to reproduce the problem at hidden link and 've escalated the matter to our 2nd tier support.
I'll get back to you as soon as there's some progress or more information.
Your patience and cooperation is highly appreciated.
Regards.
September 5, 2024 at 6:15 am #16143155
Waqas Bin Hasan
Thank you for your patience and cooperation. I just wanted to update you that this 'll be fixed in WCML 5.4.0.
