Last updated by Dennis Visser 2 months, 4 weeks ago.
Assisted by: Otto.
April 9, 2025 at 11:51 am #16913032 | |
Dennis Visser |
April 14, 2025 at 4:12 pm #16930487 | |
Otto WPML Supporter since 09/2015
Languages: English (English ) Spanish (Español ) Timezone: America/Argentina/Buenos_Aires (GMT-03:00) |
Hello, I apologize for the delay in responding. I will take care of this ticket; the reply time will be shorter now. How did you create the file to import? Can you share it with us? Make sure you are following these steps to run the import: And these steps to create the file: Best Regards, |
April 15, 2025 at 7:50 am #16932130 | |
Dennis Visser |
Hello Otto, Thank you for your reply. I have created the file for import as followed: 1. I created an export file from the products in the original language When doing this, the taxanomies are not being translated. I have also tried disabling WPML, and importing the translated feed. The taxanomies are being translated, but the variable products still give issues. Also when activating WPML again, the taxanomies are still not visible/translatable in WPML. I will follow the steps that you sent to me. If you have any other tips for me, feel free to let me know! Kind regards, Dennis |
April 15, 2025 at 7:52 am #16932138 | |
Dennis Visser |
We use the WooCommerce built-in product CSV Importer and Exporter |
April 15, 2025 at 9:34 am #16932819 | |
Dennis Visser |
Hello Otto, I have followed your steps and it has worked. All the translations are coming through. I only have a problem with variable products. The variations are not automatically added. When I try to add them manually, it gives an error. Please see the screenshot attached. Could you please assist? Looking forward to hearing from you! |
April 15, 2025 at 12:18 pm #16933942 | |
Hello, Are the variations not added in the original product or the translation? If the latter, try this: 1. Navigate to WooCommerce > WooCommerce Multilingual > Attributes tab. Next, go to WooCommerce > WooCommerce Multilingual > Settings tab, click on the Troubleshooting link (bottom right), and select: Click Start to synchronize variations across languages. If the issue persists, navigate to WPML > Support > Troubleshooting page and press: Best Regards, |
April 16, 2025 at 12:21 pm #16938666 | |
Dennis Visser |
Thanks for the assistance. It has been solved 🙂 |
