You are trying to change the image of a product for the German language on your site but the image is not updating through Media translation.
First, ensure that you have uploaded a different image for the German version of the product. After uploading, you need to scan the page to adjust the changes. For detailed guidance, please refer to our documentation on how to display different media per language.
Additionally, verify by visiting the German product page to see if the image displays correctly. If issues persist, we recommend trying the upload process again.
If this solution does not resolve your issue or seems outdated, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. If you still need assistance, we highly recommend opening a new support ticket at WPML support forum.
Last updated by Dražen 1 year ago.
Assisted by: Dražen.
May 14, 2025 at 12:27 pm #17032066
ketanS-3
I am trying to change the image of the product through Media translation for the German language on my site hidden link.
The image of the product is not getting changed through Media translation.
May 14, 2025 at 12:43 pm #17032318
Dražen
once you check, please share the access details of your website, so I can log in and take a look.
I’m enabling a private message for the following reply.
We have strict policies regarding privacy and access to your information.
Please see:
- Please backup the site files and database before providing us access.
- If you have a staging site where the problem can be reproduced, it is better to share access to the staging site.
Drazen
May 15, 2025 at 10:13 am #17036160
Dražen
I have checked and I can see you have not uploaded any other image.
You need to upload different image there and then scan page to adjust changes.
Please check our guide:
- https://wpml.org/documentation/getting-started-guide/media-translation/#how-to-display-different-media-per-language
Drazen
May 15, 2025 at 11:11 am #17036510
ketanS-3
Thats the issue i have uploaded the image there and then scan page to adjust but even after this then image is not changing on backend as well as frontend. After doing this again when i open the Media translator it show the old image only.
May 15, 2025 at 12:08 pm #17036745
Dražen
I have just tried to test with my previous image and it works fine, image attached.
You can also check if visiting DE product page, it shows fine.
Please try again.
Drazen
