You need to export WooCommerce products as a CSV file with both English and Arabic details of each product in a single row. The default and other plugins' export options separate the languages into different rows.
Unfortunately, achieving this directly with WPML or standard plugins is not possible as it requires a custom solution. We recommend contacting one of our certified partners who can provide the necessary custom assistance for your project. You can find a suitable contractor through our contractors page. Before proceeding, please also review what type of work you can expect from our contractors at this link.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need assistance, please open a new support ticket at our support forum.
Last updated by Itamar 11 months, 2 weeks ago.
Assisted by: Itamar.
September 23, 2024 at 11:50 am #16209293
deepsonT
I need to export WooCommerce products as a CSV file. I need both English and Arabic of each product in a single row with all details. I tried some plugins and WooCommerce by default export options, but all are showing CSV files with English and Arabic separately. I need a solution where if one product has English and Arabic, it needs to be in a single row, like all other products' English and Arabic details should be in a single row. Please provide any query or plugin or support plugin or any pro version plugin that supports this.
CSV export options are showing English and Arabic separately instead of in a single row.
Is there a plugin or method to export WooCommerce products with both English and Arabic details in a single row in a CSV file?
September 23, 2024 at 2:22 pm #16210340
Itamar
WPML Supporter since 02/2016
I'm sorry, but what you are trying to achieve is impossible using WPML. You are looking for a custom solution that is out of the scope of our support forum. If you need further help with what you are trying to achieve, I would suggest you consider contacting one of our certified partners from this link:
https://wpml.org/contractors/
Before doing so, please have a look also here:
https://wpml.org/documentation/about-wpml-contractors/what-type-of-work-you-can-expect-from-contractors/
With our contractors, you might get the custom assistance you need to get on with your project.
Itamar.
