The client was experiencing an issue with translating a message displayed when an incorrect account login attempt was made on their website. They wanted to translate the English message into Thai.
1. We deactivated and reactivated the String Translation plugin on the client's site and re-translated the string. After this, the translation appeared correctly in Thai.
2. We advised the client to search for the string in the "default" domain, which contains the default strings of WordPress. We also recommended enabling the option "Look for strings while pages are rendered" on the String Translation page, reloading the login page to capture the untranslated string, and then searching for the string in the admin area. After finding and translating the string, we suggested disabling the option.
If you're experiencing a similar issue, we recommend trying the steps mentioned above. However, please note that the solution might be irrelevant due to it being outdated or not applicable to your case. If these steps do not resolve your issue, we highly recommend checking related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Should you need further assistance, please open a new support ticket.
Our next available supporter will start replying to tickets in about 4.11 hours from now. Thank you for your understanding.
Last updated by Long Nguyen 7 months ago.
Assisted by: Long Nguyen.
April 15, 2024 at 7:50 am #15517439
laurentC-27
I'm have a problem with translate in WPML
April 15, 2024 at 9:28 am #15518577
Long Nguyen
I deactivate and re-activate the plugin String Translation on your site and re-translate the string. Now you can see the translation string displayed in the Thai language correctly.
April 16, 2024 at 10:23 am #15524130
laurentC-27
Hi , we still have problem with translate
Can you help to check the case incorrect password as attached ?
Link : hidden link
April 17, 2024 at 2:25 am #15528751
Long Nguyen
You should search for the string in the "default" domain, they are the default strings of WordPress.
Note: on the String Translation page, you can enable the option "Look for strings while pages are rendered" > Reload the login page to see the un-translated string > Go back to the admin area and search for the string > Disable the option.
