I'm trying to translate or duplicate all our products from English to other languages. But I only can translate the descriptions, not the viarations. So after translations there are some issues: 1) the products have no attributes/viarations I will need to set them all up over again, in 8 languages. is there other ways that I don't need to do this manually? 2) Products automatially show " not available to order" after translation. even it's in stock.
Thank you I installed and followed and it's good now. But the products I translated before doing so were still showing no stock. Is it a way I can delete the previous translations and re-generate new ones? Now when I move those unwanted pages to trash, the front-end will show page 404 when I switch to that language. I'd like it to be re-generated, or just fall back to the original language page.
For the products that are already translated before following our guide, could you please try the following steps?
1. Restore the translations from the trash
2. Edit the original product
3. Make a small change and update the product
4. Update the translation and check if the variations are showing now
Please go to WooCommerce > WooCommerce Multilingual & Multicurrency > Attributes tab, and make sure that the attributes used with those products are translated.
Then scroll down and click the "Synchronize attributes and update product variations" button. Once the process is complete, check again if the issue is resolved.
