You are using WPML to translate content from German to French, and some images are not displaying on the translated pages. The issue is due to broken image links where the 'uploads' folder is missing from the URL.
We recommend checking the format of your image links to ensure they include the 'uploads' folder. This problem might be related to a known issue with SVG support when WPML Media is activated, which strips the 'uploads' folder from the SVG image URL. For a workaround, please visit the following documentation: WPML Errata on SVG Support.
If this solution does not apply because it is outdated or not relevant to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If issues persist, please open a new support ticket at WPML Support Forum.
Last updated by Andrey 1 year, 7 months ago.
Assisted by: Andrey.
September 25, 2024 at 8:17 pm #16222390
walterS-22
I have used WPML to automatically translate our German content to French on the site hidden link.
Some images are not showing anymore in the translated pages.
What could be the reason for images missing in the translated pages?
September 25, 2024 at 8:55 pm #16222516
Andrey
WPML Supporter since 06/2013
After reviewing your website, I noticed that the images are missing due to broken image links. The format of the link is hidden link, and it's missing the "uploads" folder.
You may be encountering a known issue. Please follow the link below for a workaround:
https://wpml.org/errata/svg-support-activating-wpml-media-strips-uploads-folders-from-svg-image-url/
