You are trying to import posts via an XML file using WP All Import and WPML All Import, and the posts should be linked to each other based on the same ID. However, some imported posts are not linked despite having the same ID.
We recommend checking the following guides to ensure you are following the correct steps:
The imported file should have an identifier to connect the two languages.
If this solution does not resolve your issue or seems irrelevant due to being outdated or not applicable to your case, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. Additionally, if you need further assistance, please open a new support ticket at WPML support forum.
Last updated by Osama Mersal 1 year, 2 months ago.
Assisted by: Osama Mersal.
June 21, 2024 at 12:29 pm #15775058
denisR-17
I am trying to import posts via an XML file using WP All Import and WPML All Import. The posts should be linked to each other based on the same ID.
Some imported posts are not linked between each other despite having the same ID.
Why are some imported posts not linked between each other despite having the same ID?
How can I ensure that all imported posts are correctly linked?
June 23, 2024 at 1:25 pm #15794837
Osama Mersal
WPML Supporter since 02/2020
First of all, sorry for the late reply; it was due to a higher workload.
Please check the following guides and make sure that you follow the mentioned steps:
1- https://wpml.org/documentation/related-projects/wpml-export-and-import/
2- https://wpml.org/documentation/related-projects/wpml-export-and-import/
Osama
June 24, 2024 at 11:56 am #15806601
denisR-17
We followed the guides. Everything seems to be connected correctly. The posts have Unique Identifier. But still some of the posts import completely correctly, and some do not have a connection between them.
June 24, 2024 at 12:17 pm #15806864
Osama Mersal
Thanks for your update. Could you please upload the files you use to import the posts to any file transfer services, such as Google Drive?
After uploading the files, please share the URL with me so I can check them.
Osama
June 24, 2024 at 3:09 pm #15808704
Osama Mersal
Thanks for the file. Please log in to this sandbox site and import your posts. (hidden link)
Osama
June 25, 2024 at 11:46 am #15820125
denisR-17
Hello Osama,
I imported "Nieruchomości" posts on sandbox. I did it manually from a previously uploaded file.
Unfortunately, I fail to reproduce the problem. I would be happy to forward your login information so you can see the original page and judge for yourself where the error might be coming from.
On the original site, we use import from FTP. There are cron tasks set up on the server that fire off the imports.
Is it correct that posts in Polish and English have the same publication time? Could the error be caused by this?
June 25, 2024 at 12:02 pm #15820342
Osama Mersal
Thanks for your update. Could you please check if the issue persists in a minimal environment by following these steps?
1- Deactivate all the plugins except those active ones on the sandbox site.
2- Switch to a WordPress default theme like Twenty Twenty-one.
3- Run the import manually as you imported it on the sandbox site.
4- Use the exact files you used on the sandbox site.
If the issue is gone, activate them one by one to see which one is causing an interaction issue.
❌ Please backup your database before performing the above test ❌
Osama
June 25, 2024 at 1:09 pm #15821156
denisR-17
Unfortunately, I can't do it on the live site.
I created a copy of the site and imported the file there manually, just as I did with sandbox (without disabling plug-ins or switching the theme), and there, too, the posts were linked correctly.
I think I will merge each of the posts manually at this point, because due to the changing files sent by the ESTI program on client's server, I am not able to reproduce the problem.
June 25, 2024 at 1:13 pm #15821185
Osama Mersal
Thanks for the update. If the manual import works correctly on the site's copy, the issue might be caused by the import method.
Please let me know if you need further assistance regarding this issue.
Osama
