The client was experiencing an issue where after importing a CSV file with Slovak language for products using the WooCommerce native option, the products were duplicated in both SK and CZ languages. However, these duplicates were not functioning as translations.
We identified that the issue was related to the import/export plugin not being installed or activated during the export of the product list. Once the client activated the plugin, it added the necessary information to the WooCommerce native export feature, resolving the problem.
If you're experiencing a similar issue, we recommend checking if the import/export plugin is installed and activated before exporting your product list. This should ensure that the correct information is included for translations during the import process.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. If the issue persists, we highly recommend checking the related known issues, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If you still need help, please don't hesitate to open a new support ticket in the WPML support forum.
This topic contains 1 replies, has 2 voices.
Last updated by Prosenjit Barman 1 year, 5 months ago.
March 15, 2024 at 8:48 am #15413203
jakubZ-16
I have csv file with slovak language for my products, but after importing via woocommerce native option I have duplicated products in SK and CZ language but it works as product not as translation
March 15, 2024 at 10:35 am #15413865
Prosenjit Barman
WPML Supporter since 03/2023
Hi There,
As per our discussion, I've converted the chat to a ticket. Please take your time to do the test and share the update in response to this ticket. I will be happy to help if you need further assistance in this matter.
Prosenjit
March 25, 2024 at 9:33 am #15445443
jakubZ-16
The problem was in import / export plugin. I haven't had installed / activated it while exporting list of products. After activating the plugin, it added additional information for woocommerce native export feature. Problem has been solved.
