The client reported inconsistencies in product sorting across different language pages on their WooCommerce site, even after previous code adjustments.
We provided custom code to ensure consistent sorting by date, SKU, price, and popularity across all language versions of the site. Here are the steps we recommended:
//Use the below snippet when sorting by price and popularity, so that SKU is used as the secondary sort option:
add_filter('posts_clauses', 'custom_orderby_with_secondary_sku', 20, 2);
function custom_orderby_with_secondary_sku($clauses, $query) {
    if (!is_admin() && $query->is_main_query() && is_woocommerce() && isset($_GET['orderby'])) {
        $orderby = $_GET['orderby'];
        // Define primary column and direction based on ordering
        switch ($orderby) {
            case 'price':
                $primary_column = 'wc_product_meta_lookup.min_price';
                $primary_direction = 'ASC';
                break;
            case 'price-desc':
                $primary_column = 'wc_product_meta_lookup.max_price';
                $primary_direction = 'DESC';
                break;
            case 'popularity':
                $primary_column = 'wc_product_meta_lookup.total_sales';
                break;
            default:
                return $clauses; // Not a target orderby value, leave alone
        // Set ORDER BY with SKU as secondary sort
        $clauses['orderby'] = "
            {$primary_column} {$primary_direction},
            wc_product_meta_lookup.sku ASC
    return $clauses;
If this solution does not resolve your issue or seems irrelevant due to updates or specific circumstances, we recommend opening a new support ticket. Additionally, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. For further assistance, please visit our support forum at WPML Support Forum.
Last updated by edmondC-2 1 month, 1 week ago.
Assisted by: Bigul.
June 12, 2025 at 6:00 pm #17131147
edmondC-2
I have checked, and there are still some inconsistencies. I have put out the product sorting options to see the effect.
Refer to the following links for more details:
June 13, 2025 at 6:47 am #17131847
Bigul
WPML Supporter since 01/2013
We are working on this and will get back to you as early as possible. Please wait.
Bigul
June 16, 2025 at 10:26 am #17138114
Bigul
I had added the following code in functions.php, and it is showing the expected results after that. Please check it and let us know your feedback.
function custom_woocommerce_meta_query( $q ) {
    // Only run on main WooCommerce shop or product category/taxonomy pages
    if ( ! is_admin() && is_woocommerce() && is_main_query() && isset($_GET['orderby']) ) {
        // Get current meta query
        $meta_query = $q->get( 'meta_query' );
        // Add your custom meta query (example: show only products with custom_field = 'yes')
        $meta_query[] = array(
            'meta_key'     => '_sku',
            'meta_value' => 'ASC',
        // Set the modified meta query
        $q->set( 'meta_query', $meta_query );
add_action( 'woocommerce_product_query', 'custom_woocommerce_meta_query' );
Bigul
June 17, 2025 at 1:48 am #17140535
edmondC-2
Hello, even after adding the code you added, there are still some inconsistencies in the sorting; Here is one of the links:
Could you please update it again? I need the sorting of both language pages to be consistent regardless of the sorting method or category on the store page. Thank you
June 19, 2025 at 4:41 am #17148563
Bigul
Thank you for the updates. I am checking with our team about this for an expert opinion. We will get back to you soon. Please wait.
Bigul
June 20, 2025 at 10:21 am #17153770
Bigul
We are still exploring a possible workaround to achieve this, but there are some limitations. So, shared the details with our team for a detailed review. We will get back to you as soon as possible. Please wait.
Bigul
June 25, 2025 at 8:10 am #17167533
Bigul
We are getting the expected result after testing the following code. I have already updated it on your staging site. Please clear all types of caches and check if everything is now working as expected.
//The following code is used when no sorting option is selected — it defaults to sorting by date and then SKU.
add_action('pre_get_posts', 'custom_modify_shop_query', PHP_INT_MAX);
function custom_modify_shop_query($query) {
    // Only intervene on front-end shop or product category/tag archives
    if ( !isset($_GET['orderby']) && !is_admin() && $query->is_main_query() && ( is_shop() || is_product_category() || is_product_tag() ) ) {
        // Set meta_key so SKU ordering works
        $query->set('meta_key', '_sku');
        // Set orderby to array: first by date, then by SKU
        $query->set('orderby', array(
            'date'       => 'DESC',
//Use the below snippet when sorting by price, so that SKU is used as the secondary sort option:
add_filter('posts_clauses', 'custom_orderby_price_then_sku', 20, 2);
function custom_orderby_price_then_sku($clauses, $query) {
        // Determine price column and sort direction
        if ($orderby === 'price') {
            $price_column = 'wc_product_meta_lookup.min_price';
            $price_direction = 'ASC';
        } elseif ($orderby === 'price-desc') {
            $price_column = 'wc_product_meta_lookup.max_price';
            $price_direction = 'DESC';
        } else {
            return $clauses; // Not price-based ordering, skip
        // Use SKU from meta lookup (already joined by WC)
            {$price_column} {$price_direction},
    return $clauses;
For your kind information, if you still need further assistance with this, we kindly recommend contacting a developer, as this involves custom development work. Thank you for your understanding and cooperation.
Bigul
June 26, 2025 at 12:54 am #17171071
edmondC-2
Hello, I noticed that the ranking based on popularity is still inconsistent
June 27, 2025 at 9:41 am #17176836
Bigul
Please check the following links now. The sorting is working as expected (the secondary SKU sorting is also applied when sorting products by popularity) after updating the code as shown below.
        switch ($orderby) {
            case 'price':
                break;
            case 'price-desc':
                break;
            case 'popularity':
                break;
            default:
    return $clauses;
Bigul
July 2, 2025 at 2:31 am #17190494
edmondC-2
Hello, after using this code, the sorting is consistent. Thank you for your help. Thank you
