You are finding it difficult to translate your website after installing WPML and the String Translation plugin.
We recommend deactivating WPML and the String Translation plugin, deleting them, and then installing a fresh copy of WPML 4.9.0. This approach resolved the issue in a test environment and should display the AI Translation step in the WPML Setup wizard correctly on your site. Please verify if this resolves your issue.
If this solution does not apply to your case, or if it seems outdated, we highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please do not hesitate to open a new support ticket at WPML support forum for further assistance.
100% of people find this useful.
Last updated by Govard-Jan 2 months, 2 weeks ago.
Assisted by: Itamar.
February 12, 2026 at 2:03 pm #17815055
Govard-Jan
You’re making it increasingly difficult to simply translate a website.
I installed WPML including the String Translation plugin on hidden link" target="_blank" rel="noopener" data-saferedirecturl="hidden link">hidden link. When I try to configure WPML, something already goes wrong at step 2. My installation is at hidden link" target="_blank" rel="noopener" data-saferedirecturl="hidden link">hidden linkwp-admin and English should be at hidden link" target="_blank" rel="noopener" data-saferedirecturl="hidden link">hidden link, but it shows hidden link" target="_blank" rel="noopener" data-saferedirecturl="hidden link">hidden linken instead. I leave it like that and continue to the next steps, but at step 4 I get a blank screen and can’t do anything anymore. I disabled all plugins except WPML, and that doesn’t work either.
Submitting a support ticket also doesn’t work because you require a code, and when I try to get it from that URL (hidden link" target="_blank" rel="noopener" data-saferedirecturl="hidden link">hidden linkwp-admin/admin.php?page=sitepress-multilingual-cms%2Fmenu%2Fdebug-information.php) I get this error message: “You do not have permission to view this page.”
In other words, I can’t proceed there, and when I click skip, I see NO tickets in my support history. I’ve tried this twice. I’m becoming less and less enthusiastic about your plugin. And before you say that it doesn’t work with the “here” folder — at least 26 installations of WPML on various websites work that way.
I would really like to hear from your support team
February 12, 2026 at 3:01 pm #17817517
Itamar
WPML Supporter since 02/2016
Languages: Hebrew (עברית )
I am sorry for any inconvenience you may have experienced.
Could you please explain what is at hidden link?
In other words, what is the /here/ folder that you mention?
Privacy and Security Policy
**IMPORTANT**
Itamar.
February 15, 2026 at 11:46 am #17823387
Itamar
Hi, Govard-Jan de Jong, and thanks for the access details.
I can see the problem on WPML's setup screen. Indeed, it is stuck at stage 4.
Can you please try resetting WPML and see if that helps resolve the problem?
To reset WPML, please go to WPML -> Support, and click the Troubleshooting option. Then scroll down to the Reset section. Check the 'I am about to reset all translation and language data.' And click the 'Reset and deactivate WPML' button. Please see the attached screenshot. After this, please activate WPML and try to set it up again.
If it does not work, please allow me to take a copy of your site. To do this, I must install a plugin such as Duplicator or All-in-One Migration. Please let me know if you agree.
Itamar.
February 16, 2026 at 8:27 am #17824591
Govard-Jan
It is still going to step 4 and hangs. I have already installed Duplicator. I agree to make a copy
February 16, 2026 at 12:16 pm #17825588
Itamar
I checked on a copy of your site on my local server and found that deactivating WPML and Strings Translation, deleting them, and installing a fresh copy of WPML 4.9.0 resolved the issue. I just did the same on your site, and the problem is fixed. Step 4 - AI Translation in the WPML Setup wizard is working—the screen is displaying, and you can continue with the setup. Please see the attached screenshot.
Can you please confirm that this issue is fixed now?
Itamar.
February 16, 2026 at 3:28 pm #17826367
Govard-Jan
Thanks for the support. It was fast en good!
Kind regards
Govard-Jan de Jong
Please remove al inlays en copied website.
