Hello!
I created a website and we have 2 languages.
In the default language when placing an order, there are fields that appear according to logic. When you select a specific category, new fields appear.
This logic does not work in translation.
How to solve this issue?
Languages: English (English )Spanish (Español )German (Deutsch )
Go to WPML > String Translation and click "Translate text in admin screens" at the bottom of the page.
Here search for the strings that you use in the options page WooCommerce > Settings >Checkout, then mark the string, add it to WPML String Translation, and translate it.
You will find all available strings of this plugins by searching for "wooccm".
Question:
Are you trying to set different conditions per language at WooCommerce > Settings > Checkout > Order settings?
If so, you need to follow my earlier instructions and search for the stings:
order
conditional
conditional_parent_key
conditional_parent_value
Those strings have numeric values, in some cases I suppose "1" should refer to that an option is enabled while "0" should mean that an option is disabled.
Other numeric values can actually be higher here, and I truly do not know what they refer to.
Somehow it is not very clearly designed here which option relates to which setting.
The topic ‘[Closed] Issue with conditionals in checkout’ is closed to new replies.
Manage Cookie Consent
Functional
Always active
Preferences
Statistics
Marketing
