Last updated by Shekhar Bhandari 1 year, 3 months ago.
January 19, 2025 at 4:11 pm #16610717
agnesP-3
I am trying to translate menu links using the WPML plugin in combination with Elementor. The Finnish menu should redirect users to the correct Finnish-language pages, but it is redirecting to Estonian language categories. Link to a page where the issue can be seen: hidden link
In the Advanced Translation Editor, I am able to translate the text elements of the menu, but there is no option to translate the links within the menu. After manually updating the links directly in Elementor for the Finnish version of the menu, the links reverted the next day and redirected users to the Estonian version of the website instead of the Finnish version.
How can I ensure the links stay properly translated and do not revert?
January 20, 2025 at 3:41 am #16611599
Shekhar Bhandari
WPML Supporter since 03/2015
Thank you for reaching out to WPML support. I’m happy to assist you with this issue.
Could you confirm if the links added to the menu include translations? If translations are available, the menu should automatically display the translated links.
Additionally, please ensure you’re following the steps outlined here to translate menus: https://wpml.org/documentation/getting-started-guide/translating-menus/.
January 21, 2025 at 4:47 pm #16619991
agnesP-3
The links are on the Estonian page. Could you help me to fix it?
The Elementor icon list element is used.
January 22, 2025 at 5:24 am #16621029
Shekhar Bhandari
Hello there,
Can you provide me more informations about the issue?
Few screenshots will be helpful.
Further, To debug this issue further, I would need to check your site settings once, for this I would need temporary access (wp-admin and ftp) to your site.
Note:
Backup your sites before providing the credentials or if possible provide credentials for the test site.
Look forward to your reply.
January 22, 2025 at 8:44 am #16621533
Shekhar Bhandari
Hello there,
I added the following xml to your site to register those urls, not they are available for translations. But they are still not automatically translated.
Being so, can you try the solution from this ticket: https://wpml.org/forums/topic/mega-menu-elementor-links-are-not-updating/#post-16529536 and see if it helps.
It looks like you site is cached so any modifications I did to the code wasn't showing so I suggest to clear the cache completely before testing this further.
January 24, 2025 at 7:12 am #16630402
agnesP-3
The link you sent is a private link and I can't open it.
January 24, 2025 at 7:23 am #16630410
agnesP-3
Why aren't the links available for translation in advanced translation manager?
January 24, 2025 at 7:50 am #16630495
agnesP-3
I saw these links in string translation management, translated links, it worked for a while and now links are back in Estonian.
It looks like something is overwriting the translations. Could you look into it?
January 24, 2025 at 7:55 am #16630516
Shekhar Bhandari
Hello there
Please check the following steps:
1- Open .../wp-content/plugins/elementor/includes/widgets/icon-list.php.
2- Look for line 758.
3- Replace:
<a <?php $this->print_render_attribute_string( $link_key ); ?>>
With
$wpml_current_lang = apply_filters( 'wpml_current_language', NULL );
$item['link']['url'] = apply_filters('wpml_permalink', $item['link']['url'], $wpml_current_lang, true);
$this->add_link_attributes( $link_key, $item['link'] );
<a href="<?php echo $item['link']['url']; ?>">
4- Edit the template in the default language
5- Make a minor edit and update it
6- Update its translation
Let me know if this helps.
The topic ‘[Closed] Issue with Elementor Menu Links and WPML Translation Editor’ is closed to new replies.
