Last updated by Otto 5 months, 1 week ago.
Assisted by: Otto.
October 16, 2025 at 4:20 pm #17491485
julienM-21
I am trying to display correct posts on the French version of a specific page. The page in question is hidden link. I expected to see only 'portfolio' posts from three categories: second-edition-zombies-fr, additional-sets-zombies-modern-fr, and fort-hendrix-fr. The English version of the page, hidden link, displays correctly.
On the French version of the page, besides the correct posts, it also displays 'portfolio' posts from zombies-promo-fr and additional-sets-products-modern-fr, which are not supposed to be there. The issue persists across different post elements like Masonry and Portfolio Grid. The incorrect items are from another taxonomy.
Why does the French version of the page display incorrect 'portfolio' posts?
How can I ensure only the correct categories are displayed on the French page?
Please note that this not a cache issue, the exact same problem persists on production, on staging, on local, and even on a completely different host and setup.
October 16, 2025 at 5:40 pm #17491969
Otto
To be able to investigate the problem we need to replicate the issue on a clean installation.
I created a clean installation of WordPress, Enfold, WPML, and all necessary WPML add-ons.
You can access the WordPress dashboard using the link below:
- Don't restore your site there.
- Try to replicate the issue with minimal steps
- Then let me know the steps to see the problem
Best Regards,
Otto
October 19, 2025 at 1:18 pm #17496932
julienM-21
Hello Otto
I have no idea how to replicate the issue. My issue is precisely that I don't know WHY it happens, on this page, and this page only, despite every settings being correct.
I can provide access to the site for you to check.
October 20, 2025 at 2:03 pm #17499846
Otto
I would like to request temporary access (wp-admin and FTP) to your site to take a better look at the issue.
It would be better to a testing site where the issue is replicated.
Maybe I'll need to replicate your site locally. For this, I'll need to temporarily install a plugin called “Duplicator” or "All in One WP Migration" on your site.
This will allow me to create a copy of your site and your content.
Once the problem is resolved I will delete the local site.
**IMPORTANT**
- If you do not see the wp-admin/FTP fields this means your post & website login details will be made PUBLIC. DO NOT post your website details unless you see the required wp-admin/FTP fields.
Best Regards,
Otto
October 21, 2025 at 1:57 pm #17503373
Otto
You provided me a link to edit the translated page using the WP editor. But when I try to open the translation following the + sign, it opens with the Classic Translation Editor.
This makes me suspect that at some point the editors were mixed, which is not recommended, and it may lead to inconsistent content.
I suggest you to try the following;
- Go to Pages
- Switch to French using the language switcher in the admin bar
- Delete the page "Galerie Zombies Modern Zombicide"
- Empty the trash
- Then translate the page again this way:
This should allow you to select the categories in each page per language, because you'll be able to have full edit control.
Let me know if this is a suitable workaround for you and if it works.
Best Regards,
Otto
October 21, 2025 at 4:47 pm #17503999
julienM-21
I have followed the steps you advised, and the result is the same.
Back: hidden link
Front: hidden link
October 21, 2025 at 8:10 pm #17504546
Otto
It's weird 🤔
Changing the portfolio categories has an effect in the translated page. It looks like there is a mismatch in the taxonomy assignment.
Please take a look here:
and
Note that there are many more portfolio items in the French category. Can you please review them?
Best Regards,
Otto
October 22, 2025 at 12:16 pm #17507706
julienM-21
After many many tests, I found a workaround.
To remove the wrong posts from hidden link
I had to remove 'additional-sets-products-modern-fr' portfolio_category from the posts here hidden link
and 'modern-zombicide-zombies-fr' portfolio_category from the posts here hidden link
All posts had 2 categories, 1 parent category and one child category.
But in the first case, I had to remove the child category while in the second case, it is the parent category I had to remove.
Fortunately, in my situation, those categories were not absolutely necessary, but it doesn't help sorting things out, and it's still an issue, even if I don't understand where...
I suspect something linked to Taxonomy translation / hierarchy but I had checked that already.
October 22, 2025 at 2:30 pm #17508709
Otto
I am glad you managed to sort it out.
It looks like and edge case, or it may be related to how the categories were added and translated. It's hard to tell. But we need to understand how to reproduce it in order to solve it 🙁
If you figure out the scenario that leads to this problem, let us know and we'll take a look.
Best Regards,
Otto
