The client is experiencing issues with the MegaMenu on a multilingual WordPress site using WPML. In the German version, the Products menu item shows categories but no products, and clicking on a category leads to an incorrect URL.
1. We reviewed the MegaMenu code and found that the product categories were added but were pointing to the wrong URLs. We updated the code to be language-aware by adding a WPML language parameter and setting the language before querying products.
2. We also checked the slug translation issue and found that WordPress does not allow duplicate slugs across languages, which is not controlled by WPML.
3. We recommended setting up a staging site and activating a default WordPress theme to confirm if the issue is caused by the custom menu walker in the theme. If the problem persists, it may require custom development.
Please note that this solution might be outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum.
Last updated by Carlos Rojas 11 months, 2 weeks ago.
Assisted by: Carlos Rojas.
March 23, 2025 at 4:07 pm #16848984
daniellaR-2
I am working on a multilingual WordPress site using WPML. The site is translated, but there is an issue with the main navigation. In the English version, the second navigation item is the WooCommerce Shop Page with 5 product categories: Stokbord, Locata, Duraplas, Tapetile, and Protrack. Hovering over Products on the homepage displays these categories and their products. Clicking on Stokbord takes you to a properly styled page.
In the German version, the Products menu item is shown as Shop with the 5 categories underneath but no products. Clicking on Stokbord takes you to a different URL: hidden link instead of hidden link.
Why are the products not displayed under the categories in the German version?
Why does clicking on Stokbord in the German version lead to a different URL?
March 23, 2025 at 4:08 pm #16849013
daniellaR-2
Hi, can you please add matt@squidd.co.uk to this ticket for updates and notifications.
March 24, 2025 at 10:15 am #16851023
daniellaR-2
Hi, can I get a update on this please. We are due to go live with the German version of the website ASAP.
March 25, 2025 at 2:03 am #16854488
Osama Mersal
First of all, sorry for the late reply; it was due to a higher workload.
1) I'm afraid we can't add emails to the ticket, as our system automatically sends replies to the email in your wpml.org account.
2) Please let me know how this menu is created and translated. Do you use a plugin for the mega menu?
Osama
March 25, 2025 at 8:54 am #16855446
daniellaR-2
Hi Osama,
Our nav is implemented using this code:
<div class="nav--main__wrap <?php if (is_product()) : ?>nav--product <?php endif; ?>cf">
<?php wp_nav_menu(array('menu' => 'Primary Menu', 'menu_class' => 'nav nav--main cf', 'menu_id' => 'nav--main', 'container' => 'ul', 'walker' => new Centriforce_MegaMenu())); ?>
</div>
There is no translation to German in the Menu menu as per the attached screenshots.
I am unable to create a new Translated Menu because the Categories do not appear in the choices.
March 25, 2025 at 5:38 pm #16859319
Osama Mersal
Thanks for your update. I would need to look closely at your site, so I would need to request temporary access (WP-Admin and FTP)
❌ Please back up your database and website ❌
Osama
March 26, 2025 at 5:00 pm #16864504
Osama Mersal
Thanks for the access details. I created a German menu, but I couldn't find the code for the mega menu. (hidden link)
In order to translate the menus, please go to WPML-> WP Menu Sync, sync the menus, edit the translated menus in Appearance-> Menus, and save them.
Osama
March 26, 2025 at 9:34 pm #16865677
daniellaR-2
Thanks for all your help so far Osama I really appreciate it,
The code for the MegaMenu is here \themes\centriforce\includes\walkers\Centrforce_MegaMenu.php:
<?php
class Centriforce_MegaMenu extends Walker_Nav_Menu
function end_el(&$output, $item, $depth = 0, $args = [], $id = 0) {
$classes = $item->classes;
$output .= "";
if ($depth > 0 && !is_int(array_search('stackable', $classes))) :
//Start menu item flex-wrapper
$output .= '</div>';
endif;
return $output;
function start_el(&$output, $item, $depth = 0, $args = [], $id = 0)
$is_heading_class = in_array("heading", $classes) ? "heading" : "";
if ($depth > 0) :
$output .= '<div class="sub-menu-col ' . $is_heading_class . ' ">';
endif;
$output .= "<li class='" . implode(" ", $classes) . "'>";
//Replace page-anchors with a span
if ($item->url && $item->url != '#') {
$output .= 'url . '">';
} else {
$output .= '';
$output .= $item->title;
//Close page-anchors with a span
$output .= '
} else {
$output .= '</span>';
//Load category products
if ($item->type_label === 'Category'):
$output .= $this->_render_submenu_products($item);
endif;
private function _render_submenu_products($item)
$args = array(
'post_type' => 'product',
'post_status' => 'publish',
'ignore_sticky_posts' => 1,
'posts_per_page' => '12',
'tax_query' => array(
array(
'taxonomy' => 'product_cat',
'field' => 'term_id',
'terms' => $item->object_id,
'operator' => 'IN'
array(
'taxonomy' => 'product_visibility',
'field' => 'slug',
'terms' => 'exclude-from-catalog',
'operator' => 'NOT IN'
$products = new WP_Query($args);
$output = '';
if (count($products->posts)) :
$output .= '<ul class="sub-menu-products-wrapper">';
foreach ($products->posts as $product) :
$output .= '<li class="sub-menu-product">'
. $product->post_title
endforeach;
$output .= '';
endif;
wp_reset_query();
return $output;
So I can see that the product categories are added but these are still pointing to the wrong URL i.e. hidden link instead of hidden link
And obviously the products under each category are not displaying.
March 27, 2025 at 3:43 am #16866011
Osama Mersal
1) The URL (hidden link) is redirected to the page URL (hidden link).
This also happens to the English product URL. (hidden link)
2) I installed a local copy of your site to check the issue further and deleted the "Centriforce_MegaMenu.php" file, but the megamenu still appeared in English correctly. (Kindly check this hidden link">screenshot)
Please empty this file on your site and check the megamenu.
Kindly note that supporting custom themes is out of our support scope. Please check our support policy.
Osama
March 27, 2025 at 9:44 am #16867205
daniellaR-2
Thanks Osama,
The megamenu is actually in this file \themes\centriforce_new\includes\walkers\Centrforce_MegaMenu.php.
I have updated the code so it is language aware now:
// Add WPML language parameter
$current_lang = apply_filters('wpml_current_language', NULL);
$args = array(
array(
'operator' => 'IN'
array(
'field' => 'slug',
// Add WPML language query
'suppress_filters' => false
// Set language before query
do_action('wpml_switch_language', $current_lang);
$output = '';
// Get translated product data
$translated_id = apply_filters('wpml_object_id', $product->ID, 'product', true, $current_lang);
$translated_title = get_the_title($translated_id);
$translated_permalink = get_permalink($translated_id);
. $translated_title
endforeach;
$output .= '';
endif;
wp_reset_query();
return $output;
To summarise, the Mega Menu works fine in the English version but not the German version where it is not displaying products.
I will use this product (Stokbord® Sheet - Embossed) as an example:
When I look in the Categories section (see screenshot) I can see it assigned the Product category of Stokbord.
Using the WPML Translation Editor there is no way of ensuring the correct Category is assigned to the Product in German.
I assume this uses the Taxonomy translations (screenshot attached)
However, when I visit this page: (see screenshot)
And click on the pencil icon for the German translation of Stokbord, the screen shows the slug as stokbord-de. If i change this to stokbord it saves but changes it back.
See screenshot.
If you visit this page:
It is a correctly rendered version of the Stokbord brand page which uses the brand.php page template.
However clicking on the Produkte -> Stokbord menu option navigates you to :
Which is the incorrect page and uses the woocommerce product-cat.php template.
March 28, 2025 at 9:36 am #16871692
Carlos Rojas
WPML Supporter since 03/2017
My name is Carlos, and I’ll be taking over this ticket as my colleague Osama is currently on vacation.
I’ve carefully reviewed the entire thread, and it appears the issue is caused by the custom menu walker in your theme. To confirm this, you can set up a staging site and activate a default WordPress theme — you’ll likely see that the problem no longer occurs.
Resolving this will require custom development, which unfortunately goes beyond the scope of our support. Since this involves custom code, we recommend reaching out to one of our certified WPML contractors who specialize in multilingual development:
https://wpml.org/contractors/
They'll be happy to assist you further with a tailored solution.
Regarding the slug translation: this limitation comes from WordPress itself — it doesn’t allow duplicate slugs across languages. This is not something WPML controls.
Please let me know if there’s anything else I can assist you with. I'm happy to help with anything within our scope.
Carlos
