Last updated by Long Nguyen 1 year, 3 months ago.
Assisted by: Long Nguyen.
October 26, 2023 at 7:19 am #14666829
sorenP
I'm having issues with 2 types of elements: translating phrases that contain emojis and translating the title of a "Details" block in WordPress.
I have been trying to prepare a staging environment for you to test the issue, but I can't get WMPL development mode to work.
So first I need to solve this issue.
1. I added WPML develompment site key directly into my config.php using this reference:
https://wpml.org/es/faq/automatic-wpml-registration-using-php-for-easy-moves-between-production-development-and-staging/
2. I have the "Development Site" tag on the top of the page. See image error-print-wpml-main-page.png #1
3. But It seems I have issues with WMPL settings I can't see anything in my Translation management page. See image error-print-wpml-main-page.png #3
*** I want to keep separate translation services in my dev site from my main site (Gluu.biz)**** This staging environment is just for test and bug reports. hidden link It need the WPML service, buy I don't want automatic translations in gluustage.
October 27, 2023 at 2:32 am #14674857
Long Nguyen
Hi Soren,
We can handle one issue per ticket as our support policy. In this ticket, I will focus on the site-moved banner issue.
It looks like you've moved your site to a live site and select "No" in the banner. If you want to continue using the staging site, please try two solutions below:
1. On the staging site, click on "indicate that this site should be at - staging site".
On the live site, click on "Yes" (copy).
2. Or follow the workaround in the ticket below to remove the banner on the staging site.
https://wpml.org/forums/topic/this-site-has-moved-to-a-new-locationthis-site-has-moved-to-a-new-location/#post-14251147
Refer documentation https://wpml.org/documentation/translating-your-contents/advanced-translation-editor/using-advanced-translation-editor-when-you-move-or-use-a-copy-of-your-site/
Look forward to your reply.
October 27, 2023 at 10:00 am #14677227
sorenP
Thanks, I applied solution No. 2 for removing the banner on the staging site.
