Last updated by taiyoF 1 year, 10 months ago.
Assisted by: Eran Helzer.
July 7, 2023 at 5:35 am #13964059 | |
taiyoF |
I am trying to: Make a multilingual blog post page using Blog Posts Block on my site. Link to a page where the issue can be seen: hidden link I expected to the "load more" button should have URL query "&lang=ja", but not. |
July 7, 2023 at 7:49 am #13965309 | |
Eran Helzer Supporter
Languages: English (English ) Hebrew (עברית ) Timezone: Asia/Jerusalem (GMT+03:00) |
Hi, Can you please provide your WPML debug information? You can see exactly how to do that here: From looking at the network tab while loading more posts in Japanese, I see that the Please try enabling the following setting, if you haven't already. This is useful when loading content using backend calls, as the "Load More" button does. |
July 7, 2023 at 8:45 am #13966161 | |
taiyoF |
Thank you for your message. The problem, loading the wrong language causes language query lacking, goes on after I set Language filtering for AJAX operations. On WebInspector, the network tab tells me that &lang=ja lacks on the Load More button. Request URL: |
July 7, 2023 at 9:11 am #13966479 | |
Yes I see. This may be caused by several factors. I would like to request admin access to your site, in order to have a look. I will not be making any changes whatsoever, just looking. I have set your next reply to be private so you can share credentials there. |
July 11, 2023 at 6:09 am #14010067 | |
Perfect, thank you. I can't manage to log in, I believe because of Jetpack. Would it be possible to disable it temporarily while I investigate the issue? |
July 11, 2023 at 9:13 am #14012107 | |
taiyoF |
Thank you for your check. I set the Jatpack login management feature off. |
July 12, 2023 at 5:15 am #14018691 | |
Great, that worked. After some investigating, I managed to find the source of the issue and a possible solution. The issue is that the language the Blog Posts uses is not the current frontend language, rather the wpml_current_admin_language_{hash} cookie language. If you want to see, clear the cookies from the site, open the page while your admin language is in Japanese and then posts will load in Japanese. This solution would be to add a function to the functions.php file, which upon rendering the Button block, alters the data-next attribute to add the lang={current language) parameter. If you can provide me with FTP credentials I will attempt a solution, however it is important to explain that this is outside of our support policy, and thus we will not take any responsibility for maintaining or providing further support for it. This will be just a friendly suggestion to help you out. |
July 12, 2023 at 5:29 am #14018703 | |
taiyoF |
Thank you! It's great information. function weichie_load_more() { $ajaxposts = new WP_Query([ 'post_type' => 'publications', 'posts_per_page' => 6, 'orderby' => 'date', 'order' => 'DESC', 'paged' => $_POST['paged'], 'lang' => pll_current_language(), ]); $response = ''; if($ajaxposts->have_posts()) { while($ajaxposts->have_posts()) : $ajaxposts->the_post(); $response .= get_template_part('parts/card', 'publication'); endwhile; } else { $response = ''; } echo $response; exit; } add_action('wp_ajax_weichie_load_more', 'weichie_load_more'); add_action('wp_ajax_nopriv_weichie_load_more', 'weichie_load_more'); |
July 12, 2023 at 7:06 am #14019231 | |
That's also interesting, haven't though of that. Actually, I was thinking more along the lines of: add_filter( 'render_block', 'modify_newspack_blocks_homepage_articles', 10, 2 ); function modify_newspack_blocks_homepage_articles( $block_content, $block ) { if ( 'newspack-blocks/homepage-articles' !== $block['blockName'] ) { // Not the block we're interested in. return $block_content; } // Use a DOM parser to modify the HTML content. $dom = new DOMDocument(); @$dom->loadHTML( mb_convert_encoding( $block_content, 'HTML-ENTITIES', 'UTF-8' ), LIBXML_HTML_NOIMPLIED | LIBXML_HTML_NODEFDTD ); // Find the element with the data-next attribute. $xpath = new DOMXPath( $dom ); $elements = $xpath->query( '//*[@data-next]' ); $current_lang = apply_filters( 'wpml_current_language', NULL ); foreach ( $elements as $element ) { $url = $element->getAttribute( 'data-next' ); // Add your parameter to the URL. $new_url = add_query_arg( 'lang', $current_lang, $url ); // Update the attribute. $element->setAttribute( 'data-next', $new_url ); } // Save the modified HTML and return it. $block_content = $dom->saveHTML(); return $block_content; } This code finds the Load More button element and adds the lang parameter to the data-next attribute. This approach is usually not recommended as it could impact site performance, so I suggest you test out both approaches and choose the least impactful option. |
July 13, 2023 at 7:30 am #14029331 | |
taiyoF |
Thank you Eran, Your information helped me a lot. Thank you. |
July 13, 2023 at 7:31 am #14029345 | |
taiyoF |
Thank you. |
