The client has a multilingual site with Spanish as the root language and English as an additional language. They have configured a robots.txt file for the Spanish version, which includes SEO configurations for both languages. However, they noticed that the English version (/en/) has a robots.txt file without any configurations and lacks a sitemap file. The client is concerned about the potential SEO impact.
We confirmed that search engines do not look for robots.txt files in language-specific folders, so this will not impact SEO. However, to address the issue of the unconfigured robots.txt file in the English directory, we provided a temporary workaround:
1) Ensure you have a full site backup.
2) Open the
functions.php
file in your Child theme for editing.
3) Add the following code to the bottom of the file:
add_filter( 'rewrite_rules_array', 'remove_robots_rewrite_rules' );
function remove_robots_rewrite_rules( $rules ) {
unset( $rules['robots\.txt$'] );
return $rules;
4) Save the changes.
5) Go to Settings >> Permalinks and resave the settings.
We are currently working on a permanent fix and will update the client as soon as it is available.
Last updated by Bigul 4 years, 6 months ago.
Assisted by: Bigul.
May 17, 2021 at 5:34 pm #8783205
ievgeniiB
I have my site in two different languages Spanish, which is my root language, and english /en/. For my root (Spanish) language I specified robots.txt with sitemap which includes pages/posts/categories also for English version of my site. And I realised that for added (English) /en/ language there are also exists file robot.txt but without any configs and there are not sitemap file. So my question is: should I ignore /en/robots.txt with sitemap if I have already configured everything for my root language and how it can impact on SEO?
FYI: You can check these files by accessing them through my website. I'm also using Yoast SEO plugin.
Thank you!
May 18, 2021 at 4:34 pm #8793601
Bigul
To help you faster, I've enabled debug information for this support ticket. Please see this link for how to get this information from your site and give it to us: http://wpml.org/faq/provide-debug-information-faster-support/
Normally it will not be an issue. But I will consult about this with our developers. It requires further checking.
I hope you are following this documentation for multilingual SEO - https://wpml.org/documentation/related-projects/using-wordpress-seo-with-wpml/
Bigul
May 18, 2021 at 4:49 pm #8793671
ievgeniiB
Here is my debug information.
May 19, 2021 at 4:22 pm #8802297
Bigul
Thank you for the Debug information. Search engines will not look for robots.txt in the language folder. So it will not have an SEO impact.
But I have reproduced the issue in a fresh installation on your sandbox site and escalated the ticket to our second-tier team for further checking. Please check the following URLs for more details. We will get back to you as early as possible. Please wait.
Default language URL - hidden link
Secondary language URL - hidden link
Bigul
May 31, 2021 at 7:29 am #8878859
Bigul
The ticket is escalated to our developers for further debugging and fixing. But we have a workaround for this bug for the time being. Please try the following steps after a full site backup and let us know your feedback.
1) Open the functions.php file your Child theme for edit
2) Add the following code to the bottom of the file
	return $rules;
3) Save changes
4) Visit Settigs>>Permalinks and resave the settings
We will get back to you soon when we have an update from our developers on this. Please wait.
Bigul
