The client is experiencing issues with the translation memory in WPML not retaining the 'targetlanguage' string when minor edits are made to a page. This results in the need to manually re-enter the language parameter for the SayIt! shortcode across different translations.
We recommend performing a full backup of your site before making any changes. If you encounter issues with translation memory not retaining settings after edits, try accessing the translation first and clicking the 'save translation' button before editing the original English version. This approach may help in preserving the translation memory settings. Additionally, consider using the translation glossary to automatically populate terms like 'targetlanguage' to your desired language code (e.g., 'it-IT'), which could save time.
If this solution does not resolve your issue or seems outdated, please check for related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and ensure you have installed the latest versions of themes and plugins. If problems persist, we highly recommend opening a new support ticket at WPML support forum for further assistance.
Last updated by Kor 1 year ago.
June 28, 2024 at 6:11 pm #15853694
jonathanB-74
I am building a language learning website for children featuring extensive usage of the text-to-speech plugin SayIt!. It uses a shortcode with language parameters, such as: [sayit lang="it-IT"]. The original language is English. Sometimes, I want the TTS to stay the same across different translations. For example, I might have a phrase in English that I'm trying to teach in a lesson (e.g. [sayit lang="en-GB"]Hello![/sayit]. At other times I want the parameters to change depending on the translation (for example, [sayit lang="fr-FR"]Bonjour[/sayit] for the French page, etc. The way I've gone about this is to have a placeholder parameter for the sections I do want to change, for example [sayit lang="targetlanguage"]. Using string translation, I look for the string "targetlanguage" and I translate it to whatever I want (e.g. fr-FR, it-IT). Link to a page where the issue can be seen: hidden link
The problem is every time I make a minor edit to the text of any page, and then update each translation in the advanced translation editor, it seems like the translation memory "forgets" that the string "targetlanguage" should be "it-IT", etc. I have to go through and manually re-enter this. This doesn't seem normal.
Is there a way to "lock" certain strings into the translation memory so it doesn't get deleted every time I make a minor edit?
June 28, 2024 at 6:15 pm #15853733
WPML Supporter since 08/2022
Thanks for your patience.
Here is the ticket. I will need to closely examine your website. Therefore, I will require temporary access (WP-Admin and FTP) to a test site where the problem has been replicated, if possible. This will enable me to provide better assistance and determine if any configurations need to be modified.
June 30, 2024 at 7:38 pm #15863289
Thanks for your reply.
I've checked and didn't notice any issues. Could you please record a short screen recording using the free tool hidden link ? This will help me replicate the problem and find a solution for you.
July 1, 2024 at 1:33 pm #15868921
jonathanB-74
Here is a loom video that shows the error I have: hidden link
What I did notice when making this video is that if I click to update and save the translation immediately before making a minor edit, it seems to preserve the parameters.
July 1, 2024 at 5:37 pm #15870056
I've tried to perform minor edits to this page hidden link as shown in this screen recording and it still works fine hidden link .
Does it have to be some sort of specific edits to replicate the issue?
July 2, 2024 at 12:00 am #15870907
jonathanB-74
I noticed while filming the loom video that sometimes I have the issue, and sometimes I don't.
The issue tends to happen if I go straight into editing the English version, and then do the translation (say in Italian). Then all the targetlanguage -> it-IT gets lost.
On the other hand, if at first (before editing the English version), I click in the translation, and just click the big green "save translation" button at the bottom, before I start editing the English version, then when I make the minor edits, if I go back to the Italian translation, most of the time the translation memory gets saved (but not all the time).
I guess this is my best workaround at the moment.
On another note, is there a way of making the translation glossary automatically populate the terms that I've specified (i.e. "targetlanguage" automatically translates to "it-IT")? At least that would save me a little bit of time.
July 2, 2024 at 10:25 am #15874394
Thank you for your response.
The glossaries are stored at hidden link , as shown in the attached screenshot.
I've reviewed the strings you translated, and they are all present. Therefore, they should automatically appear when the corresponding records match.
I believe the issue arose when you edited the entire page, including inserting spaces and modifying HTML code. This action likely prompted the Advanced Translation Editor to rescan the entire page content.
July 4, 2024 at 5:06 am #15888751
jonathanB-74
Thanks very much Kor, much appreciated
