The client needs to generate a product feed for Google in a secondary language and currency using WooCommerce Multilingual & Multicurrency.
We recommend using SEO plugins like Yoast or Rank Math in combination with the WPML SEO plugin to generate content feeds in both default and translated content. For more details, check the following documentation:
However, for specific requirements like including currency in the feed URLs, a custom solution might be necessary. Additionally, you can explore solutions discussed in the WPML forums regarding similar issues with Google product feeds and currency:
If these resources do not fully address your needs, we suggest developing a custom solution.
If the solution provided here becomes irrelevant due to updates or does not suit your specific case, please check related known issues at https://wpml.org/known-issues/, verify the version of the permanent fix, and confirm that you have installed the latest versions of themes and plugins. Should you need further assistance, feel free to open a new support ticket at WPML support forum.
Last updated by 1 year ago.
Assisted by: Waqas Bin Hasan.
