If you are using the Site Editor and add a menu to your template using the Navigation block, you need to send the Navigation Menu to translation via the Translation Management Dashboard. This allows you to use the Advanced Translation Editor to translate the menu items, including the links.
For more, see the page about translating menus in Site Editor templates.
Last updated by daniel-viktorV 1 year, 11 months ago.
July 7, 2023 at 12:35 pm #13968009
daniel-viktorV
As you requested in another ticket (https://wpml.org/forums/topic/greenshift-not-showing-translations/), I will create a new ticket for this problem:
As you can see on my site (hidden link) the menu is structured to be accessed from a hamburger menu (also on desktop). This is implemented with the 'traditional' WP core navigation block. However, when I try to translate the navigation items (using the FSE template translation description), WPML simply does not recognize the menu items (neither the titles nor the links).
What could be the problem here?
Thanks in advance!
July 7, 2023 at 3:46 pm #13969379
Marcel
before your ticket is assigned to one of my colleagues, please allow me to walk you through some initial debugging steps. This will help speed up the support process.
Please open WPML -> Translation Management and select the affected navigation menu in the dropdown "Navigation menu", that you use on the specific page/template.
Start a translation of this menu and search for "http" in the ATE search window, then you can manually adjust the URLs to /en etc. We are already working on a workaround to rewrite this to the translated ID automatically. However, our "Translate Link Target" function must first be modified to make REST requests possible.
More information, you can find here: https://wpml.org/faq/how-to-translate-urls-shortcodes-and-html-attributes-using-the-advanced-translation-editor/.
Best Regards
Marcel
