You are working on a site under development and trying to add an extra field using
wcml_custom_prices_fields
. The field appears properly, but after saving, its value does not appear.
We recommend adjusting your code as follows:
add_filter( 'wcml_custom_prices_fields', 'add_custom_price_fields', 10, 2 );<br />function add_custom_price_fields( $fields, $product_id ) {<br />// Add a new custom price field<br />$fields[] = '_purchase_cost';<br />return $fields;<br />}<br /><br />add_filter( 'wcml_custom_prices_strings', 'set_labels_for_price_fields', 10, 2 );<br /><br />add_filter( 'wcml_custom_prices_fields_labels', 'set_labels_for_price_fields', 10, 2 );<br />function set_labels_for_price_fields( $labels, $product_id ){<br />// Edit the label of a custom price field<br />$labels[ '_purchase_cost' ] = __( 'Purchase cost', 'woocommerce-multilingual' );<br />return $labels;<br />}<br /><br />add_filter( 'wcml_update_custom_prices_values', 'add_purchase_cost_to_custom_prices', 10, 3 );<br />function add_purchase_cost_to_custom_prices( $custom_prices, $code, $post_id ) {<br />    $type = get_post_type($post_id);<br />    if ( 'product' == $type ) {<br />        $purchase_cost = get_post_meta($post_id, '_purchase_cost' . '_' . $code, true);<br />               if (isset($_POST["_custom_purchase_cost"][$code])) {<br />            $purchase_cost = $_POST["_custom_purchase_cost"][$code];<br />        }<br />    } elseif ( 'product_variation' == $type ) {<br />        $purchase_cost = get_post_meta($post_id, '_purchase_cost' . '_' . $code, true);<br />        if (isset($_POST["_custom_variation_purchase_cost"][$code])) {<br />            $purchase_cost = $_POST["_custom_variation_purchase_cost"][$code][$post_id];<br />        }<br />    }<br />$custom_prices['_purchase_cost'] = $purchase_cost;<br />return $custom_prices;<br />}
If this solution does not resolve your issue or seems outdated, please check the related known issues and verify that you have installed the latest versions of themes and plugins. If the problem persists, we highly recommend opening a new support ticket at WPML support forum.
This topic contains 22 replies, has 0 voices.
Last updated by marioG-45 10 months, 1 week ago.
Assisted by: Dražen.
May 1, 2025 at 8:54 am #16985977
marioG-45
Hi Dražen,
Okay Waiting for the solution.
May 5, 2025 at 4:33 am #16994196
marioG-45
Hi Dražen,
Any update regarding the variable product?
May 5, 2025 at 5:53 am #16994313
Dražen
There were holidays and weekend in Europe, so most of the team was OFF, so it is taking a while.
I will update you when I have some news, should be today or tomorrow.
Drazen
May 7, 2025 at 5:44 am #17004228
marioG-45
Hi Dražen,
I hope you are doing well.
Okay I'm waiting for the response. I hope I'll get the solution asap.
May 7, 2025 at 12:49 pm #17006646
Dražen
For the label, you should additional hook that reuses your code for the label:
and for saving value, the data for the variation is saved in a separate value - _POST["_custom_variation_purchase_cost"][$code][$post_id].
So finally working code on test site looks like this:
return $fields;
return $labels;
Drazen
May 7, 2025 at 1:04 pm #17006732
marioG-45
Hi Dražen,
Thanks for the update.
I'll test above code tomorrow and let you know.
May 7, 2025 at 1:11 pm #17006755
Dražen
sure.
You are free to see the test site, where it works fine:
- hidden link
Drazen
May 8, 2025 at 5:53 am #17009804
marioG-45
Hi Dražen,
I have noticed that on the test site you installed the below plugins as well, which I think its necessary.
Plugins:-
1. WooCommerce Multilingual & Multicurrency
2. WPML Multilingual CMS
3. WPML String Translation
On my staging site I have just installed WooCommerce Multilingual & Multicurrency and
now I have installed rest of the two plugin as well.
But for now I just want to work on English language I don't want to add any other languages on the site. So if those two plugin is necessary in that case I want to add any other language on my site which I don't want to add.
So now what happen is if I can't add any other language on site my setup will stay remaining and i can't see that purchase cost field in product.
See the screenshot:-
1. hidden link
2. hidden link
So could you please check it and let me know on urgent basis.
If you are available for call then we will meet on google meet and discuss.
May 8, 2025 at 6:29 am #17009887
Dražen
We do not provide support over the phone or similar, it is only via forum/chats.
As for other plugins, you do not need them if you are using only WooCommerce Multilingual & Multicurrency.
For custom code, you will probably need to further adjust it to your custom environment / approach, but as you can see in test site it works fine. You can use that working code as example, but if you need further adjustments to your website / code I am afraid we can not help with custom coding and custom debugging, it is out of scope of our support.
For custom coding you can use service of WPML contractors:
- https://wpml.org/contractors/
Hope this makes sense.
Drazen
May 8, 2025 at 6:34 am #17009904
marioG-45
Yes but in your testing site you added the two languages.
Could you please create one more testing site and add only multi currency plugin and test it?
So I can show you what exactly happing.
May 8, 2025 at 6:37 am #17009905
Dražen
I have already before my reply, disabled plugins and confirmed it works fine without extra plugins and with only WooCommerce Multilingual & Multicurrency.
You are free to check.
Drazen
May 8, 2025 at 7:26 am #17010036
marioG-45
Hello
Okay let me check and get back to you.
May 8, 2025 at 7:29 am #17010037
Dražen
Sure, but as said before, maybe you have not understood my reply, it is already like that on the test website, and it works fine:
You are free to check it out.
Drazen
May 8, 2025 at 7:31 am #17010061
marioG-45
Okay sure let me check and get back to you.
May 8, 2025 at 8:58 am #17010366
marioG-45
I have just review the testing site which you provided. In that site I have noticed that for default currency the purchase cost field is not coming why?
Screenshot:- hidden link
Could you please check it and let me know.
