Last updated by Bigul 1 year, 2 months ago.
Assisted by: Bigul.
March 31, 2024 at 12:02 pm #15467246
פפוצ’ון השקעות בע”מ
in the Hebrew translation, i want to change the "IsrApart" at the main menu to the word "home" in Hebrew, and i want to delete the IsrApart from where it says "אודות ISRAPART".
And at the search bar, for some reason it doesnt translate the word "Children", and if we scroll down when we are still in the Hebrew you can see that the "Services" widget is not translated and i couldnt find how to do it, didnt found the matching strings.
and lastly, because Hebrew is from right to left, i need help with adjusting Phone numbers because i want them to be from left to right, and also some text elements that were moved to the right of the screen and now it doesnt look good with the design
March 31, 2024 at 1:07 pm #15467328
פפוצ’ון השקעות בע”מ
need help please
March 31, 2024 at 6:03 pm #15467483
Bigul
WPML Supporter since 01/2013
We hope you are trying the steps suggested here for translating the Menu - https://wpml.org/documentation/getting-started-guide/translating-menus/#easy-customizable-wp-menus-sync
It may be possible to fix this by translating the Menus manually into Hebrew or translating the Custom Menu items via String Translation. Refer to these links for more details.
https://wpml.org/documentation/getting-started-guide/translating-menus/#fully-custom-create-menus-manually
https://wpml.org/documentation/getting-started-guide/translating-menus/#translating-custom-links-after-wp-menus-sync
If the issue exists, please visit Appearance>>Menus switch to Hebrew via the dashboard language switcher(of top header), and share a screenshot of it.
I have a request. Please upgrade the following configurations for the better performance of the site.
1) Increase *WP Memory Limit* to *256* MB(the minimum required memory limit for WPML is *128*). Please check the following links for more details
https://developer.wordpress.org/apis/wp-config-php/#increasing-memory-allocated-to-php
2) Increase the *MaxInputVars* of PHP settings to *10000*. Please check the following article for more details and contact your system admin/hosting provider to upgrade this configuration.
Bigul
The topic ‘[Closed] need help with main menu, to chenge and correct words, and with missing strings’ is closed to new replies.
