Last updated by Waqas Bin Hasan 1 year, 2 months ago.
Assisted by: Waqas Bin Hasan.
February 3, 2025 at 12:47 pm #16662732
nickyd-3
I am trying to change my location to UAE and test the payment in AED. The issue can be seen on this page: hidden link
When I change the location to UAE, I expected to pay in AED, but instead, I got Euros.
Why can't I change the payment currency to AED when I set the location to UAE?
How can I ensure the payment is processed in AED instead of Euros?
February 4, 2025 at 8:53 am #16665313
Waqas Bin Hasan
WPML Supporter since 05/2014
Can you please check this guide for following sections and see if you've configured this as needed?
- Currencies Based on Location
- Currencies Based on Language
Please let me know.
Regards.
February 4, 2025 at 9:04 am #16665403
nickyd-3
Hi, it was always Currencies based on Location and we used VPN to change the location. We were able to make the payment in AED and it was functional. But its has stopped working suddenly. Even with VPN we are not able to checkout in AED. It's always converting into Euros. I have attached the screenshot of the Multicurrency settings page.
February 4, 2025 at 11:31 am #16666338
Waqas Bin Hasan
Thank you for the updates.
I see you've selected "Client Location" in your screenshot but not using MaxMind. Are you using another method of detecting location? And when it was working previously, were you using maxmind or any other approach for detection? I'm trying to understand that what'd have changed between previously-working and now not-working (i.e. any update like plugins, theme or etc).
Can you please try the following?
1) Take a full backup of your site and database before proceeding. It is highly advised to try these on a dev or staging site first, so your live site isn't compromised.
2) Deactivate all plugins except WPML, String Translation, WCML and WooCommerce.
3) Switch to a standard theme like 2024 or 2021.
4) Check for the issue if it still happens.
Please let me know and I'll try my best to help you further on the matter.
February 7, 2025 at 1:37 pm #16680093
nickyd-3
Sorry, for late reply. In this case, I have shared the staging site and admin details. If possible please have a look and let us know:
**** credentials removed for security reasons ****
February 10, 2025 at 5:56 am #16684981
Waqas Bin Hasan
Thank you for the access, I'll check soon and 'll get back to you accordingly.
P.S.: I've removed credentials from the public message. Please always ask for the private message to share such information or it may appear publicly and can be misused.
February 10, 2025 at 12:30 pm #16687048
Waqas Bin Hasan
Thank you for your patience and cooperation, I am still working on this and 'll get back to you by tomorrow on this.
February 11, 2025 at 4:45 am #16689897
Waqas Bin Hasan
I'm trying to login to your staging site at hidden link this morning, but looks like the credentials are not working anymore, please see attached.
Please check on your side and if you need to provide new credentials, I've set your next reply as private.
P.S.: If you don't see the section for providing access information, do not write in the message box or the information may appear as public.
February 19, 2025 at 5:16 am #16721746
Waqas Bin Hasan
Thank you for the access, I was able to login. I am working on this and 'll get back to you as soon as I find something or have a solution.
February 19, 2025 at 7:59 am #16722507
nickyd-3
Thank you so much.
February 19, 2025 at 11:59 am #16724108
Waqas Bin Hasan
I've tried by adding my country (Pakistan) to the WCML's currencies list because my VPN doesn't support UAE for a location. But looks like problem is little deeper, as I've also tried various options.
I'm trying to reproduce the issue in one of my sandboxes and 'll update you accordingly (probably by tomorrow).
February 19, 2025 at 1:08 pm #16724606
nickyd-3
No worries, let me know when you figure it out!
February 20, 2025 at 6:29 am #16727339
Waqas Bin Hasan
I've tried reproducing the issue in a fresh sandbox site (hidden link one-click login). But here it is working fine.
I used "define( 'WCML_GEOLOCATED_COUNTRY', 'es' );" in wp-config.php to set a location other than mine, so I can see Euro as currency. If I remove it, I can see AED as per my current WCML multicurrency settings.
I'm using a Maxmind key (the same I've also tried in your test site) but when I use a VPN this does not work. I'm little doubtful about my VPN, so I 'll request if you can check the sandbox and see if that location based currency works fine for you. Please let me know.
On the other hand, I'll need a copy of your test site for escalation to our 2nd tier team. Currently your site produces a very large package, is it OK to remove inactive plugins, themes and media from this test site and then creating a package? Please confirm so I can proceed with it.
February 20, 2025 at 8:21 am #16727991
nickyd-3
Normally location based currency was visible but we weren't able to make the purchase in AED. In checkout page it's converting to Euro which wasn't happening earlier. I have given you the access of staging site, so you can do whatever you want. Based on your update, we can implement the changes in our live site.
February 20, 2025 at 12:50 pm #16729594
Waqas Bin Hasan
Thank you for the confirmation, I've escalated the issue to our 2nd tier team. Please leave the staging site as it is.
I'll update you as soon as there's more to it.
The topic ‘[Closed] Need help with Multicurrency’ is closed to new replies.
