Last updated by Bruno Kos 1 year ago.
Assisted by: Bruno Kos.
May 14, 2025 at 11:06 am #17031787
ericS-63
I have a multilingual site built with WPML, where English (.com) has been the original language for all products and pages. Dutch (.nl) has been used as a translation, and that content is now complete and up to date. I would like to remove English from the site and make Dutch the new original language for all content.
I understand this cannot be done automatically in bulk via the UI.
What is the safest and most efficient way to make Dutch the original language for all products and pages?
Can I use the "Set this translation as original" option in the WPML Troubleshooting section for this?
Once the switch is done, can I then remove English from WPML > Languages without affecting Dutch content?
Is there a recommended way to batch update original languages if I have hundreds of products?
May 14, 2025 at 1:03 pm #17032407
Bruno Kos
There is no one-click bulk option in the WPML UI, but there are a few practical approaches you can try to achieve this:
Option 1: Change default language to Dutch, then clean up
* Change the default language in WPML to Dutch https://wpml.org/documentation/translating-your-contents/displaying-untranslated-content-on-pages-in-secondary-languages/manage-archive-listings-default-language-change/
* Disable English under WPML > Languages
* Delete English content and translation data by following this process: https://wpml.org/documentation/getting-started-guide/language-setup/deleting-languages-and-plugin-data-by-doing-a-wpml-reset-on-your-site/#step-1-remove-the-secondary-languages-and-all-existing-translations
Option 2: Export/Import with WP All Export/Import
* Use WP All Export + WPML integration: https://wpml.org/compatibility/2016/08/export-multilingual-websites-using-wp-all-export-and-wpml/
* Export your Dutch content
* Delete all content and reset WPML
* Set Dutch as the new original language, and re-import the content
Option 3: Manual bulk delete and WPML reset
* Bulk delete all English-original content (Products, Pages, Taxonomies) via WordPress
* Reset WPML and reconfigure it with Dutch as the default language
* Dutch content will then be assigned as original
Let me know if you have any questions related to any of the above!
The topic ‘[Closed] Need to switch original language from English to Dutch for all products and pages’ is closed to new replies.
