Last updated by Alejandro 1 year, 9 months ago.
Assisted by: Alejandro.
| Author | Posts |
| July 18, 2024 at 6:07 am #15969852 | |
chen-hsienk-2 |
| July 18, 2024 at 7:35 am #15970499 | |
Alejandro WPML Supporter since 01/2018
Languages: English (English ) Spanish (Español ) Italian (Italiano ) Timezone: Europe/Rome (GMT+02:00) |
We can only handle one issue per ticket so i'll try to answer them both and then we can concentrate on one issue alone and split the ticket with the other issue in case it's not solved. 1) Is that page "mind-blogs" the "blog" page setup for the site? I mean, is it setup as the blog for that website in the WordPress options and NOT in the theme options (let me know instead if they are setup in a theme's option). 2) If you don't want the titles to be translated automatically based on the original title, then you have a few ways to go about it. All are explained on this guide i think the best one is to have the option to translate it to however you want (option "translate"): - Go to WPML → Settings. However, if ALL the slugs in your site should NOT be using the chinese characters, then you might want to encode its URLs so they all appear in the latin alphabet. - Go to WPML > Languages > Edit Languages. None of these options will affect already translated slugs, but for the you can edit the translation directly and change it manually as you wish. |
| July 18, 2024 at 7:58 am #15970700 | |
chen-hsienk-2 |
Hi, I Solve the URL problem And for the blog. i think i didnt set any thing. i think it setup in a theme's option |
| July 18, 2024 at 8:12 am #15970826 | |
To investigate the issue, I kindly ask you to grant me access to the wp-admin area of your website. I have enabled the necessary fields on my end so you can provide them to me in a secure and private manner. This way, only the two of us will be able to view them. If possible and for your safety, i'd suggest you create a new user (a fake one with a fake mail) that you can later delete when the ticket is closed. |
| July 18, 2024 at 11:52 am #15972225 | |
I'm a bit confused here. i went to you site and there is no "mind-blog", but there's a "blog" page which is empty. It's empty because it's just a page at the moment. if you go here hidden link (settings > Reading) you'll be able to change that behaviour since your current homepage is actually the blog. if you want to have a specific page set as a blog, then you have to set a homepage as well and then select a specific page ("blog") as your new blog. So, my question here is: what were you expecting at the moment and where? because i don't see any "mind-blog" so i'm not sure how i can help you 🙁 Let me know and i'll gladly help you out. |
| July 18, 2024 at 11:56 am #15972249 | |
chen-hsienk-2 |
I just recover the previous version and i would like to set up the "blog" these 2 are work well these 4 page are not working.... |
| July 18, 2024 at 12:57 pm #15972663 | |
Ok this is indeed interesting. it shows a 404 even though they actually exist in the back-end. can you tell me how did you create the homepage and where? because the entire setup is a bit atypical so it might be why we have this issue here. |
| July 18, 2024 at 1:01 pm #15972668 | |
chen-hsienk-2 |
well.... i dont know how i seted up the ome page..... I just use the theme "startace" and change the original home page it has to my style..... there was a "blog post" section in the origin original home page. but i delet it. and Create another blog page by my own. |
| July 18, 2024 at 1:03 pm #15972677 | |
chen-hsienk-2 |
And after the previous recover. there are showing like 34 published pages in my "all page" section. which there are only 18 pages as i can see |
| July 18, 2024 at 1:49 pm #15972902 | |
Hm, i only saw 3 pages in total which i see were the "intended" ones. however i tried to do some maintenance to the DB and managed to see them all. They were all like translations of the same 3 "original" pages but in other languages which was more than weird. Right now, though there are a LOT of navigation elements and more. i'm not entirely sure what happened before, but it seems like you tried to translate the content again and again which i suspect you didn't do intentionally but it was also not done by our system on its own. So, while I'm trying to figure out what's happening, can you tell me why have you been restoring the site and when did this problem appeared? it would help me understand better the entire situation and figure out why this is happening. --------------- Another thing that i ask of you is to let me know where can i find that "original homepage" you modified to your liking? because that might help me understand HOW is everything connected. |
| July 18, 2024 at 1:57 pm #15972950 | |
chen-hsienk-2 |
6 hrs ago I was trying to find out why the link of "blog" is not working at the translated page. so i just try to modify the navigation page(may be change the link or delete the page then create another "blog" page to link) and than translated it again. but none of it work. So i just decide to restore everything and set up everything again.... i think that is why. |
| July 18, 2024 at 2:45 pm #15973221 | |
chen-hsienk-2 |
hidden link this is the original page that I modify with. It suppose to be english..... but now its weri and know all the translation page is showing.........I didint do anything In these 6 hours I was facing the same problem in My previouse site. thats why I delete WordPress account and create this entire new one and build erverything again. but seems the same problem just happening in this new account.(it just happend when i Restore. I think the restore have some issue for the translated page) I dont know what to do now |
| July 18, 2024 at 2:53 pm #15973229 | |
Please watch this video: hidden link You have a lot of content that was duplicated. i don't know how or when but i managed to delete some of them. however it seems that you have a "blog" in other languages in the database but that are not showing anything. either that or you have an image with the same "blog" URL. at that point you can change the name of the blog or change the permalink structure to avoid the issue from happening again. The problem here is not really related to WPML but with something in the database, a probable "glitch" which interrupted the communication between the site and the DB and corrupted something in it. since you're in WordPress.com i don't think you can even access your own database so i can't check it out for you. |
