The client needed assistance with making the personnel and about pages display correctly in a right-to-left (RTL) orientation and translating contact forms. There were also issues with the alignment of the Hebrew languages menu and specific elements on the site not being correctly aligned for RTL.
We applied custom CSS code to the client's website to correct the RTL display issues. For the translation of the contact forms, we provided step-by-step guidance through documentation links:
If you're experiencing similar issues, we recommend checking the custom CSS on your site and referring to the provided documentation for translating contact forms.
Last updated by Kor 1 year, 10 months ago.
November 30, 2023 at 10:41 am #14960967
motiS
Hi
Personnel page not changed from LTR to RTL and contact strings not translated
The documentation I found on the site created thousands of strings that are unnecessary for translation.
I just need the personnel page and about page to be fully RTL, and to translate the contact forms.
About:
Personnel:
The contact form is not translated in all locations.
Additionally, the HEBREW languages menu is not aligned correctly (see image - both languages are glued together)
November 30, 2023 at 8:14 pm #14967201
WPML Supporter since 08/2022
Upon reviewing your debug information, I have observed that the PHP limit for your "WP Memory Limit" is lower than the recommended 256MB or the required 128MB, as mentioned in the documentation found at: https://wpml.org/home/minimum-requirements/. To resolve this, I kindly request that you contact your hosting provider and request an increase in the PHP value for you.
December 1, 2023 at 12:03 pm #14972339
motiS
Can you send me an email address? I'll use it to create a new user for you to use temporarily.
December 1, 2023 at 12:39 pm #14972591
motiS
Thank you. I sent you an email with the user information. Please let me know if there's anything else needed
December 1, 2023 at 2:05 pm #14973483
Thank you for getting back to me.
I have implemented some custom CSS code on your website. Could you please verify if the content is now displayed in a right-to-left (RTL) orientation?
Additionally, I want to inform you that our support policy allows us to address only one problem per support ticket.
Regarding the translation issue with the contact form, you can find instructions on how to translate it by referring to the following links:
1. For guidance on using Contact Form 7 with WPML, please visit: https://wpml.org/documentation/related-projects/using-contact-form-7-with-wpml/
2. To learn how to create multilingual forms using WPForms and WPML, please visit: https://wpml.org/documentation/related-projects/creating-multilingual-forms-using-wpforms-and-wpml/
December 3, 2023 at 7:17 am #14979445
motiS
Hi Kor
Thank you for your help. I have looked and there are still some features on the site that were not fully aligned to RTL. I'm including images for you to see.
- In the about section, the V bullets are supposed to be on the right before the text (it's a bullet list).
- In the contact section, where the email and phone are, the plus (+) is supposed to be on the left before the number begins.
- In the uppermost header where the WPML menu is, the two languages are stuck together - they need to be separated by some space.
Please see the images included.
December 3, 2023 at 7:18 am #14979447
motiS
Sorry I forgot to include the images!
December 4, 2023 at 9:38 am #14983819
Thanks for your reply.
I've applied some additional CSS stylings for you and the problem should be fixed. Could you recheck?
December 4, 2023 at 10:01 am #14984351
motiS
Looks good, thank you so much for all the help!
