The custom settings added by the Price Offers for WooCommerce Pro plugin are not being copied to the translated product data.
If you're experiencing this issue, we recommend you navigate to WPML > Settings > Custom Field Translations and check for the fields related to the plugin. Set those fields to "Copy". This should ensure that when translating your products, the fields are copied appropriately. For more detailed guidance, please refer to our documentation on Translating Custom Fields.
Please note that this solution might be irrelevant if it's outdated or not applicable to your case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the issue persists, please open a new support ticket at WPML support forum for further assistance.
Last updated by 1 year, 9 months ago.
