If you're experiencing issues where a popup created with Popup Maker does not open on a translated page, even though both the page and the popup have been translated, this might be similar to the issue we addressed. In this case, the popup worked on the original language page but not on the translated version.
First, ensure that the popup ID is correctly set for the translated versions. You can locate the popup id in Popup Maker > Popup. Then, manually adjust the popup ID in Button Settings > Extra > Extra Class name "popmake-153955".
If changing the popup ID does not resolve the issue, it could be related to a theme error. We recommend checking the debug log for errors and consulting with the theme author if necessary. For instance, a PHP error related to a 'call to a member function get_type() on null' in the theme's files was identified as the cause in a similar situation.
Please note that this solution might be outdated or not applicable to your specific case. We highly recommend checking related known issues at https://wpml.org/known-issues/, verifying the version of the permanent fix, and confirming that you have installed the latest versions of themes and plugins. If the problem persists, please open a new support ticket.
Last updated by Rico Heinrich 5 months, 4 weeks ago.
February 10, 2025 at 4:01 pm #16688681
Rico Heinrich
I am trying to translate a page that contains a button to open a popup using Popup Maker. The page and the popup have both been translated. However, on the translated page, the popup does not open. Link to a page where the issue can be seen: hidden link
On the translated page, the popup does not open. The CSS class "pum-trigger" is missing for the button link.
Why does the popup not open on the translated page?
Is the missing CSS class 'pum-trigger' causing the issue?
February 11, 2025 at 9:15 am #16690544
WPML Supporter since 08/2022
Thanks for contacting us.
February 11, 2025 at 4:53 pm #16692997
Thanks for your reply.
I tried to change the popmaker ID here hidden link for English, but it broke the page hidden link . Also, I deleted the English language contents and duplicated it from DE language for a test.
I tried accessing your FTP access to check the debug log, but it's empty and could you please check? Also, it says my FTP access doesn't have the permission to edit the files.
February 11, 2025 at 6:23 pm #16693249
Rico Heinrich
Thank you Kor. With this hoster only files in wp-content may be edited.
WPDebug has to be switched on from the admin panel. I just did that.
I noticed this behaviour before: when you try to save the English (translated) version of the page directly it breaks. This can only be reversed when you completely delete the translated page and create it again ...
The debug.log works now. You can also see the server error log at 246851_test/logs/ via FTP.
February 12, 2025 at 2:55 pm #16697433
Based on the debug log below, it looks like the issue is related to the theme.
[11-Feb-2025 18:16:35 UTC] PHP Fatal error: Uncaught Error: Call to a member function get_type() on null in /data/sites/web/b1400m8myrdbxio/www/wp-content/themes/uncode/woocommerce/single-product/rating.php:30
Could you maybe check the rating section of the translated product to see if anything is causing the breakdown? or check with the theme author.
Here is the Pastebin link https://pastebin.com/xNBMwxQT for your debug logg
February 12, 2025 at 6:20 pm #16698599
Rico Heinrich
Thank you Kor, I could fix that.
Now I just changed the popup to the English one and it worked.
