This topic contains 42 replies, has 0 voices.
Last updated by Andreas W. 11 months, 2 weeks ago.
| Author | Posts |
| May 29, 2025 at 7:00 am #17086186 | |
Marcel Elbers |
Hi Andreas, Thanks for taking over. We only work with the ATE, we know we must not switch between the ATE and WordPress editor. We have only worked with the ATE for translating the website. Thanks, |
| May 29, 2025 at 6:17 pm #17089486 | |
Languages: English (English ) German (Deutsch ) Timezone: America/Lima (GMT-05:00) |
Please also take note of this: When using the WPML Translation Editor it would be expected that segments that were already translated will be deleted on the WPML Translation Editor if the relative original content has been edited. Can you please clarify if this might be the reason for the issue you are reporting? IMPORTANT: |
| May 30, 2025 at 9:41 am #17091471 | |
Marcel Elbers |
Hi Andreas, RE: When using the WPML Translation Editor it would be expected that segments that were already translated will be deleted on the WPML Translation Editor if the relative original content has been edited. We can let you know when we experience this problem again but we also don't know a fixed way to reproduce this problem. Thanks. |
| May 30, 2025 at 3:10 pm #17092679 | |
Marcel Elbers |
I'm working on the website now and this post hidden link is missing a lot of the Dutch translation. This was created by copying from the live site into the ATE. thks. |
| May 30, 2025 at 4:10 pm #17092825 | |
The reason is, that the original content was changed. I can see the changes in our translation system. Each time the original content was changed or new text was added, the translation will need to be updated. I can confirm that this original content now has new text segments that did not exist in the original content the last time it was translated. Sometimes even making a small edit like a blank space on an original content can lead to that the relative segments will need to be translated again. I suggest you complete the translation, then make one small edit on the original post, save the post again, and then open the WPML Translation Editor. Do the translations remain saved, apart from the segment for which a small edit was made? |
| May 31, 2025 at 6:49 am #17093741 | |
Marcel Elbers |
Hi Andreas, The only thing i changed in the default language was the meta title and meta description with rank math. The rest everything was unchanged. I didn't touch the body of the text and look how much of the translation is missing. If changing only the meta title and meta description leads to deleting such big parts of the body the software is useless in my opinion. We are wasting a lot of time on fixing all these translations again. Where can you see what was changed in the default language? Regarding: I suggest you complete the translation, then make one small edit on the original post, save the post again, and then open the WPML Translation Editor. Do the translations remain saved, apart from the segment for which a small edit was made? Most of the time this saves the text good however we did have 1 product 2 weeks ago that also a part of the text was missing of which we translated the text very recently. I'm not able to reproduce this problem as sometimes it happens and sometimes not. If it's possible to see somewhere if edits were made in the default language I could check this before I open the post in the translation and see if text is missing in the translation. I'm 100% sure we only work with the WPML translation editor. Thanks. |
| May 31, 2025 at 7:05 am #17093745 | |
Marcel Elbers |
Hi Andreas, Now i did this text: hidden link Before I changed something 100% was translated in Spanish and Dutch. I only changed the meta description and meta title but look how much of the translated Dutch text is deleted. The Spanish a smaller part was deleted this I already restored. Thanks. |
| May 31, 2025 at 4:53 pm #17094529 | |
Thank you very much for running this test and providing me with the details. I will be taking a local copy of your site for running further tests and then get back to you. |
| May 31, 2025 at 4:59 pm #17094531 | |
When using the plugin Rankmath SEO you will need to install our addon WPML SEO which will allow you to translate the fields and strings of Rankmath SEO. https://wpml.org/documentation/related-projects/wpml-seo/ Please go to Plugins > Add Plugins and go to the Commercial tab. Here please install WPML SEO and also run the updated for WPML Multilingual CMS. I further suggest updating all plugins, like Rankmath, WooCommerce, etc. After that, please test again if you can still recreate the issue. |
| June 1, 2025 at 12:48 pm #17095462 | |
Marcel Elbers |
I doubt if installing this plugin will solve this problem. What does this plugin do/solve? For example this post: Thanks. |
| June 3, 2025 at 2:03 pm #17102736 | |
This addon will recognize the custom fields of Rankmath SEO and make them available for translation on the WPML Translation Editor. The reason the addon is currently not active on the site might be the cause of the issue you are experiencing. I would like to ask you to install the addon and test it again to see if you can still confirm the problem. Please install the addon, then edit the original page and save it. Now complete the translation to 100%. Finally, make another small edit on the original content, save the page, and open the translation editor. Can you still confirm now the issue? |
| June 3, 2025 at 2:12 pm #17102790 | |
Marcel Elbers |
ok i will try it and let you know the results. thks |
| June 3, 2025 at 2:33 pm #17102940 | |
Thank you for your message! This ticket will remain open for 14 days. |
The topic ‘[Closed] Post is translated but when opening the translation parts of the translation are empty’ is closed to new replies.
